Well-Priced Lightweight Track/Street Wheels
#46
Obviously it's more than the sheer number of spokes, (material type, barrel/lip engineering for example), but I think there's a reason John is sticking with more spokes for the CCW C10 (10 spoke) and C14 (14 spoke) that he recommends for track cars.
BTW, that post I quoted about the bent D-Force wheels was the 3rd I found like that.
Enjoy your wheels, Mark. If they hold up for you, then you've saved a bunch of money. If you bend the odd wheel, you can get it repaired. You can fix a bunch of them before you'd equal the $$$ for stronger wheels.
Cheers,
Cheers,
#48
The problem may go back to the simple 5-spoke design. The wheel has a wide area of no real support between each spoke. Enough pressure in the wrong place and it can bend.
#49
I don't know enough about the physics of a good track wheel design, but I'm sure curious about it. Kodiak is about an hour from me and the local PCA chapter was going to organize a tech night there. If that happens (or when I'm out that way next), I'll talk with them about wheel design issues.
I'm always curious about these things.
Cheers,
#52
Of course...you then completely eliminate the possibility of getting them under a 944/968 unless they ran a 9' on all 4 corners. (even then I'm not sure a 9' will fit the front of a 944).
Tough call...I, like many others, would love to see it happen though. I even think I'd go for a set of 8.5's and 10.5's as much as I'd rather see 9's and 11's.
Andy
#53
I only skim read this, but, I saw no mention of the bolt pattern. I know that BMW uses a different bolt spacing than Porsche uses. Are you getting these made with the Porsche pattern 130mm, or will adapters be required for the BMW 120mm spacing?
< ---- Happens to have a set of 1" 130mm to 120mm wheel adapters....
#56
On a three piece wheel there is no need to worry about a 5 spoke "bending" or not supporting the wheel shell. The center will not compress or come out of round and cause the wheel shell to bend. A center will crack before this would happen. Things could be different on a one piece cast wheel however.
In terms of the the wheel shells, the inner sees more load than the outer on + offset wheels. The material choice, heat treat and design of the shell play significant roles in it's strenght. 6061 T6 makes for a better product than 5000 series. I have seen 6061 parts made from .190 that when tested flex less than a similar 5000 series part made from .250.
There are variances in the way parts are designed in the area of the tire well that can have an effect on the stiffness of the part as well.
Cheers
Cheers
#57
I'm interested in a set if the sizes produced will fit a narrow body 964. Maybe an 8" and a 9" or 9.5" width?
