Wheel and Tire Forum
Urgent Tire Question: will 285/30/18's fit on a 10" rim?
Old 09-22-2007, 05:31 PM
Dale Gribble
Pocket Sand
Dale Gribble's Avatar
Default Urgent Tire Question: will 285/30/18's fit on a 10" rim?
as the title says, will they?
i know ideally they should be on an 11, but will they mount to a 10" rim properly?
the tires are pirelli's, but toyo's spec sheet on the RA-1's indicates that as high as a 305 can be used on a 10" rim.
Old 09-22-2007, 06:31 PM
eugene
eugene's Avatar
Will work just fine.
eugene.
Old 09-22-2007, 08:28 PM
Wilder
Wilder's Avatar
Received 4,854 Likes on 1,728 Posts
285 is the factory recommended size for 993 WB rears which mounts on 10" turbo twist wheels. 10" rims can accomodate up to 295 without any problems. I don't know about 305s.
Old 09-22-2007, 08:32 PM
Dale Gribble
Pocket Sand
awsome thanks!
Old 09-24-2007, 10:18 PM
Floodj
Floodj's Avatar
What about putting those tires on a narrow bodied car?
Old 09-24-2007, 10:30 PM
FLA997
FLA997's Avatar
Narrow body will take the 285s as well...I run them on mine. And if you are real savvy with camber and offsets/width you can fit a 275 up front.
Quick Reply: Urgent Tire Question: will 285/30/18's fit on a 10" rim?
