Thinking to try some new tire size for my 993 C2S
The factory tire size my my 993 C2S is:
Front 225/40-18
Rear 285/30-18
I want to try a different profile, like:
Front 225/45-18
Rear 285/35-18
What do you guys think?
Scott
Front 225/40-18
Rear 285/30-18
Front 225/45-18
Rear 285/35-18
Scott
Hi Scott
You were asking about tire size options for your 993; I have a 1995 993 for track use.
It wears 245/40 and 275/35x18 Toyo RAIs; a bit different from your set up. I have minor tire rubbing on the fronts; acceptable for track use (I hope to never have the wheel at full lock!) but it would be a pain for street use.
My street/rain tires are 225/40 and 255/35x18 Goodyear Eagle F1s and there should be good clerance, but I have not actually driven with them yet.
Hope this helps
Hope this helps
Former Vendor
Scott, the fitment will be real close up front. You are going up in OD over a half inch from stock and it could rub. Rears should be OK at stock ride height. You may tap on hard acceleration squat.
Scott,
Why not try 235/40 - 18s front and 295/30 - 18s rear? I think you will find that the diameter of the 235/40 -18 is actually the same as the 225/40-18. At least it is for the Michelin Pilot Sport PS2s.
I wouldn't want to go to a taller (225/35-18) tire. That's just my feeling
