4 lug boolts instead of 5 on my wife's A4
I realize I'm on a Porsche Board but I need some help. In switching to winter wheels/tires yesterday evening I broke the pin that you use as a guide in mounting the wheels on the wheel hub on my wife's A4.
Now I have the broken end of the pin where the 5th lug bolt should go. What's the consensus out there, will it be OK to drive the Audi, maybe 100 easy miles, until Friday and I can buy an easyout to remove the broken part of the pin?
Second question, has anyone tried to remove one of these broken pins, I assume it's no big deal to back it out, it only in finger tight? Thanks.
Louis Elsner
Louis Elsner
Ever noticed the number of rough looking american barges that lead a city live with only four lug nuts on? I would think very gentle driving in city traffic is no issue.
If the pin is finger tight only, can you not tap it with a hammer and chisel CCW until you can grab it with pliers and remove it?
Addict Rennlist
if it is just the plastic one that comes in the tool kit, try some super-glue or any other quick drying glue or epoxy to glue it back together then just unscrew it.
if that doesn't work then with the other 4 bolt properly torqued, some limited, easy driving should be ok.
Tom
Tom
OG Racing
Your Source For Motorsports Equipment
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
Sparco's Largest Distributor for 28 Years
PFC Distributor for 27 Years
Pagid, Alpinestars, MOMO, OMP, Hawk, Bell, Aim, G-Force, HJC,
HANS, Arai, Simpson, Brey Krause, Longacre, CoolShirt!
Supplying Track Junkies for 34 Years.
PCA Club Racing - National Sponsor Since 1998
A Veteran Owned Business
Check out our blog!
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
Check out our blog!
