Can You Put Off-road 20-inch Tires on 22-inch Rims?
Yes, what can fit many cars with 22-inch rims and 20 inch alloy rims? However, you should follow the measures below to ensure the fit is perfect.
The purchased 22-inch rims must have the proper bolt pattern to match the specific automobile model. The tire's sidewall should be lower, and the tires must fit the 22-inch rims. These tires are referred to as profile tires. Place the wheels and tires, ensuring there is enough space between them and the interior fenders of the automobile. If the tire grinds on the fenders, you should roll them with a body hammer. It creates more space for the wheels to fit, thereby preventing the tires from losing air pressure.
Is this some sort of AI gone rouge post?
It's spam. Not obviously, but there is one link in the post and it leads to a wheel supplier.
This entire thread "starter" is NUTS! Anyone who cares about their own safety and those of others will never try to mount incompatible tires and wheel rims. There are detailed industry standards to ensure safety of the combination and proper fitment of tires and wheels. If that thread is the product of some AI, that AI needs major "learning"; trying to fit a 20" bead diameter tire onto a 22" inch bead diameter wheel is going to break something: the tire beads, the wheel or the tire mounting machine. And if someone tries the inverse situation of mounting a 22" bead diameter tire on a 20" bead diameter wheel, it will certainly be relatively easy to mount, but the tire is not going to be seated properly against the rim if it can be seated at all.
Vitor Forgelite (04-25-2023)
