SO3 Pressure Recommendations?
Hi All,
I have Bridgestone SO3's with 225/45x17 on the front and 255/40-17 on the rear of my Carrera 3.2. Can anyone tell me the best pressure to have them? I don't drive like a lunatic also.
Cheers,
Justin
Cheers,
Justin
Check the manufacturers sticker. Pressure recommendation are by vehicle and not by tire manufacturer. A common misconception.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
It goes by load and inflation tables in that instance. I am swamped right now but I will look up minimums in the morning for you. You go from there as to what feels good to you. Do you know the vehicle weight?
Keeper of the Truth
Since these sizes were not available for your car, you need to experiment with pressures. You should probably start high and go down if you feel you have too much. How about trying 34/38? My feeling is your car should feel right in the low to mid 30's, however.
There are minimum pressures by load. You will need to experiment but there are actual min. pressure numbers. At 26 psi the 255 can carry 1132 lbs. per tire (I dont know the weight of the car) and the 225 can carry 1014lbs. at the same pressure.
Therefore, you know that you should be able to run the tires at a minumum of 26 psi (I am assuming it weighs less than 4 thousand pounds!). From there Viken is right, play with them, I defer to his 911 knowledge on the recommendation.
Your car is lighter than the newer cars. I have a 78 turbo which is a little heavier than you car. I run 18s with 28lbs in the front and 34lbs in the rear. At an auto cross I use 32 and 38.
Keeper of the Truth
Originally posted by texasgooner
I find it unbelievable there is such a wide range of pressures used with this car!
Wow, I agree with Viken (sorry V, had to throw that in there!)
Keeper of the Truth
Nothing wrong with it, just doesnt seem to happen often. Have you tried the new PS2? I seem to remember you saying you were going to give it a shot.
Keeper of the Truth
