Yes. Not sure but suspect the Tire Rack warehouses are temperature and humidity controlled. Tires should be good for five years. Expect to use them up before 5 years.
The tires are in our temperature controlled warehouse out of UV rays. Tires are good for up to 10 years from the DOT date, 5/6 years from beginning of use.
Price drop on 275/40ZR18 to $121. 245/40ZR18s are gone. Use the by size tab for the R-S4. If the same size is listed twice one is the closeout or call Brad above.. Restricted to West Coast zip codes, but I bought an 18" wheel and tire package so they shipped to Virginia. IMO this is a smoking deal if you have any desire to use/try R-S4s.
I might be interested as part of a wheel tire package for the track. I have a 2009 base Carrera. Would like in 19 inch size. Is there a special link or should I call you?
Jeff
I show the 275/40ZR18 are out of stock also now. If you want to place an order you can call 800-428-8355 EXT 4398, make sure you get Brad or leave a voicemail to me. Otherwise you can use my name online, after the shipping/billing screen, bottom left hand side put "Brad" before checking out.
Jeff
I think you are too late, but go to their website and search by brand: Hankook and then RS4. If you see the size listed twice then one of them is the 2017s. Or you can call.
