Hello
2001 911 C2
First time owner
Passenger side rear tire has bad inside wear. Driver side is looking fine. Is this a common pattern for this model 996 or a symptom of something in the suspension I should take a look at?
Thanks in advance for any advice you can provide.
get your alignment checked. Assuming no aggressive driving, you have too much camber dialed in. Also could be too much toe, but didn’t look like it to me based on the photo.
Yes I agree. Passenger side Eccentric bolts may be loose or need adjusted with an alignment. Ill try to make it more positive to the driver side in my shop. If it goes awry, will have the pro's do it.
