20x10 + 50
20x10 + 50
Will 20x10 +50 clear the front calipers of a 2013 base model 991? I need to know asap because I am going to be sponsored . Please help. And if so what offset should I run for 20x11 in the rear? Please help
Former Vendor
Not enough info on the spoke shape. The wheel width and offset doesn't mean the wheel has caliper clearance.
The OEM 20" wheel is 11" wide with a 70mm (!) offset. Your wheel will be into the well a full 33mm more, and out by 7mm. That's a pretty much guaranteed rub on the suspension/liners/ducts without moving them back out with spacers.
