S. CA Timing belt Party!
#151
if anyone want's it i'll trade for a good set of spark plug wires (maybe a 10mm nology) or some thing equal to or better
the compressor is new used once
it's by porter cable
i can't and have no use for it in germany
#153
trade would be just fine.
the way i see it, i'm getting excellent knowledge in timing belts, spark plug wires and the meet p-car owner that have "deep pocket" or not so deep as they claim.
lol
lol
#155
Originally posted by smkn951
has anyone, that is coming to the party ever done their own timing belt and adjustment that can give a class to me?
As I said if you are down the day before call me and we can do more that what the time may be available on Sunday.
#157
Can't really adjust the air/fuel ratio. Don't have the equipment. But we can discuss what changes this and why. Then you can decide if you want to tweak it.
I do have a compression gauge. Not set up for a bleed down test though.
How is your shift lever pin?
#158
the pin i think is ok but where it connects to i think the hole is a tad bit big as i have a lot of play.
also when i first start the car in the morning, i hear a loud rattle but i let it idle for 3 min. then it stops.
sound like something tapping on the cam and valve cover area.
after driving a tad bit hard (punching it in 1st upto about 4.5 rpm same in sec. and 3rd) i would then coast as the speed limit is only 35mph on post, the car would then start to idle erratic at stop signs and start to smoke.
once i get home i turn it off let sit for bout 10-15 min start it back up then it's normanl again.
will there be enough time that day to do brake pads?
do you happen to have any blue brake fluid, i tried kragen, autozone and pep boys and no one has 'em
tia
tia
#159
Try Mesa Performance in Costa Mesa. If they don't have it they can get it in a day. Use your credit card and PM me to pick it up. I'll bring it to the get together. (949) 642-8824
I'll bring a couple of the bolt and jam nut pin replacements. Think I have some thin wall tubing to make bushings from also.
Your problems sound like the turbo.
#161
carl, not all of us have turbos...just that your car WANTS to be one, lol! I've done mine with the help of Legoland951. Not too bad, took about an hour.
- Julie
- Julie
#163
how long will it take to do a rear main seal?
how 'bout the control arm bushings
will there be enough time for these or mainly timing, cam, blance shaft belts?
