Mark this thread as Unsold
95 993 C2 Coupe With Heated Hard Back Sport Seats ***DEPOSIT TAKEN - PENDING SOLD***
Year: 1995
Make: Porsche
Model: 911
Cont. Porsche Models: 993
Mileage (numbers only please): 107000
Options (Please check ALL which apply): Airbags, Air Conditioning, Alarm System, Antilock Brakes, Cruise Control, Foglamps, Intermittent Wipers, Leather Seats, Power Brakes, Power Door Locks, Power Steering, Power Windows, Sunroof
Color: Guards Red
VIN: WP0AA2991SS322216
Price (no $ sign please): $47900
Private or Dealer Listing: Private Listing
Location (Region): Canada
Body Style: Coupe
Transmission Type: Manual - 6 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: AM-FM Cassette
I have owned this car since 2009. There were 3 previous owners. It is originally a U.S. car and I imported it to Canada, so it's very easy to import it back to the U.S. and I'm a short, all hwy, 45min drive from the NY State border.
I really enjoy driving cars but my real enjoyment comes from working on them. I have a big heated garage with a lift and have done extensive work on this car putting only 7K miles on it in 7 years.
During my ownership it has only been driven on dry summer days. It has a clean Carfax (which I just purchased) as well as a clean Car Proof and Carfax from 7 years ago when I bought the car.
Below is a list of the extensive improvements and modifications I have done while I have owned it. Most parts that have been replaced were done as while I was in there type of things - the car drove great when I bought it (I drove it home, 17 straight hours) and only had the typical oil leaks associated with air cooled engines and tired suv height suspension.
I have just completed an engine and transmission drop where every while you're in there part was replaced - it has no oil leaks. The clutch and flywheel were replaced with a LW Flywheel and clutch by a previous owner at 79K miles but due to a leaking RMS I felt it best to replace it now. The suspension work was done a few years ago, but looks like the day it was installed due to the low mileage I have put on it.
Picture Links:
For Sale pics https://flic.kr/s/aHskBgdLmi
Engine Drop pics https://flic.kr/s/aHskFRg1Lc
Some of the Extra Parts https://flic.kr/s/aHskEzCT8H
Suspension
- Walrod Poly Urethane Front Control Arm Bushings
- ERP Racing Rear Toe Control Arms
- Bilstein HD Shocks and Struts
- Porsche Euro Spec (ROW) M030 Front and Rear Sway Bars and Springs
- Tarrett Front Drop Links
- Front Ball Joints
- Front Tie Rods
- Steering Rack Boots
- Porsche Steering Rack Brace
- Rennline Front Strut Brace
- Front and Rear Sway Bar Bushings
Brakes
- New front and rear Porsche Brake Rotors and Pads
- New Porsche Brake Pad Sensors
- Complete Rebuild of Front and Rear Calipers including Pistons and Seals and Powder Coating
- New Front and Rear Stainless Steel Braided Brake Lines
Transmission/Shifting
- FD Motorsports/Porsche RS short shift kit with Golden Rod
- RS Lightweight Flywheel - new Kevlar Clutch with all new Clutch Fork Shaft with Bearings and Sleeves
- New Flywheel Pilot Bearing and new Bolts
- New Clutch Slave Cylinder and Hose
- New Crank Position Sensor
Engine
- New Hydraulic Lifters
- New Porsche Rear Main Seal
- New Upper and Lower Valve Cover Gaskets and Bolts
- New Chain Cover Gaskets and Nuts
- New Oil Temperature Sending Unit
- New Oil Pressure Sending Unit
- Complete SAI System Removal replaced by Patrick Motor Sports Plugs (old SAI system included)
- New Spark Plugs
- New Beru Spark Plug Wire Set
- New Distributer Caps and Rotors
- New Fan Hub Bearing and freshly Painted Fan
- New Porsche Power Steering Belt
- New Porsche Alternator/Fan/AC Belts
- New Engine Lid Struts
- New RS Motor Mounts
- Cleaned and Painted Engine Tin with New Stainless Steel Bolts
- FD Motorsports Fister Stage III Performance Exhaust Mod
Maintenance Items
- Mobil 1 15W-50 Oil Change with new Filters
- Brake Fluid Flush
- Hydraulic Clutch Flush
- Power Steering Fluid Replacement
- New Fuel Filter
- Mobil 1 75w 90 LS Transmission Fluid Change
- Idle Stabilizer Valve (ISV) cleaned
- Mass Airflow Sensor (MAF) cleaned
Appearance items
- Heated Hardback Sport Seats (original seats included)
- Porsche 3 Spoke Steering Wheel and Airbag (original 4 spoke included)
- New Driver’s Door Seal
- New Window Switches
- Front Bumperettes removed (bumperettes included)
- Turbo Duct Fog Lights - (originals included)
- Porsche Factory Euro Clear Front Signal Lights
- Blacked-out Porsche Hood Emblem (original gold emblem included)
- RS Silver Shifter **** and Aluminum Parking Brake Handle (original black leather ones included)
- Walrod Aluminium Instrument Gauge Rings (easily removed)
- New Headlight Lenses with 3M clear film protection
- RS Wing with its own Deck Lid (complete original deck lid with motorized wing and basket handle brake light included)
- High Mount 3rd Brake Light from 96-98 993 installed
- Porsche Factory RS Front Splitters (original standard splitters included)
- Porsche Factory RS Side Skirts not installed but included
- Rennline Aluminium Pedal Set including Dead Pedal
- Porsche RS Console tray in place of Cassette Holder
- FD Motorsports Wide Oval Exhaust Tips Ceramicoated in Matte Black
- Porsche Factory MY02 18" Wheels professionally finished in flat black (5% gloss) powdercoat (original 17" Porsche Cup II wheels included)
Extra Parts Included with Sale
- Original Front Driver and Passenger Seats
- Original Porsche 17” Cup II Wheels
- Original 4 Spoke Steering Wheel
- Original Fog Lights
- Original Front Splitters
- Original Black Leather Shift **** and Parking Brake Handle
- Original Deck Lid with Basket Handle Brake Light and Motorized Wing
- Original Porsche Gold Hood Emblem
- Brand New Porsche Motorsound Airbox Cover
- Extra Dual Distributor
- Extra set of belts (Alternator/Fan/AC)
- Original Front and Rear Sway Bars and Springs
- Lots of new maintenance parts for future needs, including oil filters, oil etc.
The hard back sport seats were sourced from a rennlister's lower mileage car and are in excellent condition. Please note all of the original parts that are included with the sale including the original seats in case you wanted to sell the sport seats.
At some point a previous owner had the car re-sprayed due to rock chips and it currently has several rock chips that have been touched up. The paint looks great in pictures, but a close-up examination reveals the stone chips. I had the front bumper resprayed so I could have the ugly bumperettes removed when I had the RS wing and front splitters painted to match the car. There is some patina on the trailing bottom edge of the wheel wells from driving.
The windshield has a small stone chip that happened on my drive home from purchasing the car. The rear window area had a small rust bubble, in the common right hand corner, when I bought the car, so when I got it home I cleaned it all away to the bare metal and painted it with touch up paint - most of it is under the weather stripping and it hasn't progressed in 7 years.
I have a binder of maintenance and part receipts and records as well as an excel file of the maintenance history.
This car is perfect for someone who wants a car that has had everything sorted out mechanically and wants to drive it and not worry about a stone chip or the mileage.
If you'd like to talk on the phone you can email your number and I'll call you back as I have a long distance plan or I can give you my number. Emails are probably better than pm as I can get them on my cell. Please use this email: my993forsale@gmail.com. I'd like to sell everything as a package so the buyer will have right of first refusal on the seats. I'm not in any rush to sell and not interested in trades. Thanks - Steve
Yep, cars priced to move on this site, move quickly.
Unfortunately, most buyers can't separate emotions from reality when they set their price, and they sit here for months, woefully overpriced.
Congrats to the seller and the buyer for what looks like to be a stellar 993 and a great price
I wish more sellers would provide thorough documentation and photos as this listing. I think I could have purchased it without an on-site inspection. Well done, and congrats on the quick sale. Well deserved.
