Mark this thread as Unsold
2002 996 C2 Manual
2002 996 C2 Manual - Pics added
Year: 2002
Make: Porsche
Model: 911
Cont. Porsche Models: 996
Mileage (numbers only please): 87541
Options (Please check ALL which apply): Airbags, Air Conditioning, Alarm System, Antilock Brakes, Cruise Control, Intermittent Wipers, Leather Seats, Power Brakes, Power Door Locks, Power Steering, Power Windows, Sunroof, Traction Control
Color: Seal Grey
VIN: WP0AA29962S621085
Price (no $ sign please): $22500
Private or Dealer Listing: Private Listing
Location (Region): Texas
Body Style: Coupe
Transmission Type: Manual - 6 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: AM-FM CD
Purchased the car in '09 with 44k in perfect condition - not a scratch, ding or stain. See more pics below in additional posts.
Number built for model year 2002: 6249
Engine/Transmission: M9603-662 G9601-10 (open differential)
Paint/Interior: L6B4 AA Seal grey metallic (water based) Black standard leather
C02 - USA
226 - Tires
288 - Headlight Washers
411 - 18" Carrera wheel (996)
437 - Full power seat left
438 - Full power seat right
446 - Wheel caps with crest
478 - Porsche stability management
537 - Left seat with built-in lumbar and memory
601 - Litronic headlights
680 - Bose sound system
692 - Remote CD changer (6 disk)
Car now has 87541k, all service records back to original purchase, and receipts for all maintenance since I purchased it. The car has been well cared for and has had the following items replaced: (NEW = < 1000 mi.)
- New clutch, flywheel, pressure plate, TOB
- New RMS
- NEW LNE IMS bearing
- NEW AOS
- NEW 6 coils and plugs
- NEW sunroof drain hoses replaced with Porsche upgraded design
- NEW Clutch slave cylinder
- NEW Clutch master cylinder
- NEW Clutch pedal helper spring assembly
- NEW HID bulbs
- NEW Rennline 4 piece aluminum pedal set
- NEW front rotors
- NEW front brake pads and sensors
- NEW Function First transmission mount insert
- NEW Brake/clutch fluid replaced
- NEW transmission fluid replaced
- NEW transmission input shaft seal
- NEW cabin air filter
- NEW engine air filter
- NEW oil and filter
- NEW gas shocks front and rear deck
- Water pump and thermostat replaced
- Cooling system flushed and refilled w/ Porsche coolant
- rear rotors and pads replaced
- Wevo semi-solid motor mounts
- B&M TRAK Shifter, 30% reduction SSK (car has never been tracked)
- FisterD muffler bypass
- 3 of 4 camshaft actuators replaced
- Custom leather shifter boot
- Heat-rejecting window tint all around
- Windshield replaced
- Window regulators replaced
- Drive belt replaced
- Vacuum hoses replaced
- Battery replaced
- Headlight washers replaced
All the NEW items were recently replaced when I replaced the clutch. Once I had the transmission out I deemed it prudent to replace all accessible maintenance items as a preventative measure so I would not have to repeat the procedure for another 50k or whenever the clutch needed replacement again.
Equipped with Bose sound system w/ six CD changer. All maintenance performed at regular intervals and all service done to Porsche specifications. Tires are Advan Neova AD08 front 245's and rear 295's w/ 15mm spacers and wheels are optional 18" Porsche. Interior is black. Car was originally sold in Houston and has remained here. Clear title.
I never thought I would ever sell this car but I just purchased a 2014 370Z Nismo and the 996 sits in the garage most of the time. I decided it's pointless to have it just to have it so I decided to offer it to someone else who has always wanted to own a Porsche at a reasonable price. The best part is all the major maintenance and upgrades are done and this car should be good to go for another 50k miles!
For Rennlisters only: If I don't have to haggle over the price I will include at no additional cost:
- Durametric Diagnostic tool Enthusiast Option II (cables for 996 and 944)
- H&R Sport Lowering springs (new, never installed)
- Stainless steel brake lines (new, never installed)
- Various Porsche special tools and spare parts
- 996 Essential Companion
- Bentley Workshop Manual
- 101 Projects for your 996
- Heatshield custom fit sun shade
- Carbon fiber license plate frame
- New set of front and rear brake pads (never installed)
This car has never been tracked or abused.
Nothing's perfect...
Small ding on right rear quarter panel
Small door ding on driver door
Cowl broke free from bolt on right side (replacement about $100)
Another view of cowl
Headlights are clear
Front bumper chips (enhanced for clarity)
Small door ding on passenger door. Ding didn't scratch paint and the scuff buffed out. It is difficult to see unless you really look for it.
