Mark this thread as Unsold
1984 Porsche 944 “Kung Fu Panda 2” for Race or HPDE
3rd Gear
Year: 1984
Make: Porsche
Model: 0
Cont. Porsche Models: 944
Mileage (numbers only please): 0
Color: Blk&Wht
VIN: WP0AA0944EN452289
Price (no $ sign please): $16450
Private or Dealer Listing: Private Listing
Location (Region): SouthEast
Body Style: Coupe
Transmission Type: Manual - 5 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: None
Looking to start doing HPDE, or need a more competitive race car? This 944 has enough go fast, suspension, and safety parts to make this car equal parts both fun HPDE car -and- competitive race car.
I’ve tracked a lot of cars - Mercedes AMGs, BMW Ms, Suzukis, VW, Miatas, BMW Exx, Formula Ford, and other Porsches - and by far this Porsche 944 has been the most fun to drive.
If you know Motor Werks Racing, the Georgia shop who built and currently maintains the car, then you know this is a high quality 944. In addition to all the custom engine work, highlights of the overall package include the full weld-in cage and the MCS damper & coilover system. The MCS’s and other highly adjustable suspension components allow tuning of the car’s handling characteristics to driver skill/preference, track layout, and other conditions. The result is faster laps.
This setup has already delivered with multiple podium finishes, and a NASA GTS1 track record at Road Atlanta (1:45.855 back in 2013). I’ve only driven the car in HPDEs lately, four HPDE events in 2015 and five in 2016, for ~90 hours on the engine since race-spec build. MWR replaced the rod bearings in Sep. 2015.
Maybe you're thinking about a 1.8t engine conversion? With the MCS’s, cage, and big brake kit already in place, this 944 could also be a good candidate for install of one of the 1.8t conversions that are becoming available.
Modifications include*:
Engine:
2.5L Motor Werks Racing engine (naturally aspirated)
Balanced Injectors
Camshaft with adjustable gear
Custom Head – CC & matched ported
Custom Ported Intake manifold
Baffled oil pan
Ceramic coated pistons & rod bearings & main bearings
High Flow Fuel Pump
Four into one header with V-Band full flow exhaust, etc.
Aluminum Flywheel
Sach Motorsports Clutch Kit
Oil Cooler
Suspension:
Custom MCS remote canister damper & coilover system, custom front swaybar, adj. rear swaybar, Delrin bushings
944 Ball joint kit - Performance / Track upgrade 17 mm Long Pin
Torsion bars removed & all Delrin suspension bushings
Adjustable camber plates
Bump steer kit, tie rod end (adjustable)
Modified spring plates
Body:
Many custom & fiberglass pieces, eg: fiberglass 944 hood, Spoiler, fenders, bumpers, lightweight mirrors, etc.; Sunroof Delete; Lexan windshield, rear hatch and side windows w/Z-clips; Power Options Delete; Height Adjustable Pedals
Weight ~2,485 lbs
Brakes: Wilwood 4-piston Big Brake Kit, front brake ducts
Gearbox: Short Stack gear box with short 5th gear
Limited-slip differential
Wheels & Tires:
8x Color Matched Phone Dial Wheels - 4x 15" and 4x 16"
16” Tires – 2x 225/50 R16 Hankook Ventus and 2x 245/40 R16 Hankook Ventus
15” Tires – 4x 225/50 R15 Hoosier R6
Safety & Convenience:
Full Weld in Cage with welded seat mount
OMP HTE Race Seat OMP-HA772
OMP Passenger Race Seat (not currently installed - located in spares)
Custom 2G "Cool Suit" Box - relocated to rear
SPA 3.5 Fire Suppression System
TraqMate w/input box, power to GoPro 2 box mounted on roll bar
Driver - Schroth Profi II 6 point harness - HANS- Black
Passenger 6 Point Harness
Removable Momo Steering Wheel & Hub Adaptor
Custom Kill switch, Tow Hook, Schroth window net
Helmet hook, Steering wheel hook
2x ECUs - 1x "Race," 1x "Performance"
Spares:
Misc. cooling hoses
Brake pads
Misc. fuse relays, etc.
Fresh brake fluid
Engine oil
Car cover
Professionally maintained, to recently include:
(12/16): winterization incl. add fuel stabilizer, and put in climate-controlled storage, etc.
(11/16): R/R rear brake pads; replace pads w/performance set; bleed brakes & clutch; tension belts; clean air filter; replace rotor cap; replace MAF sensor
(09/16): Gear lube service; R/R front brake lines; bleed brakes and install stainless steel brake line; replace front control arms and hub assemblies.
...and much more.
*There are a lot of parts and frequent maintenance, so this may not be an exact list of components. Buyer must verify before completing purchase.
Author(s) maintain any copyright to these photos used under fair use. I'll take down upon request.
