Mark this thread as Unsold
86 944 turbo
86 944 turbo
Year: 1986
Make: Porsche
Model: 0
Cont. Porsche Models: 944 Turbo
Mileage (numbers only please): 89000
Options (Please check ALL which apply): Airbags, Power Brakes, Power Door Locks, Power Windows, Sunroof
Color: Garnet
Price (no $ sign please): $11000
Private or Dealer Listing: Private Listing
Location (Region): South
Body Style: Coupe
Transmission Type: Manual - 5 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: AM-FM CD
Engine was completely rebuilt under 10k ago. Full ARP bolts. Baffled sump and crank scraper. Rebuilt stock oil pump.
Lindsey super 75 and full lindsey mafia kit tunes for 91 93 and 102
16 and 18psi tunes
Clutch net stage 3 clutch and flywheel
Lindsey ac delete and Nissan alternator
Heater core bypass
Manual rack conversion
Lindsey dual port wastegate
3 inch downpipe 3 inch catless exhaust.
2PC crossover pipe conversion
Innovate boost controller ssi4
Innovate wideband lc1
Lindsey blowoff
30mm front sway bar. Poly bushings.
Koni race adjustable coil overs in front.
Turbo S Koni yellows out back
Ground controller camber plates
Strut tower bar
Cup 2 wheels 9 inch all around 3k on a set of dunlop direzza d2 star specs 245
Sparco seats with 4pt harness.
Steering wheel replacedrive unknown brand.
Interior has dash and almost all panels covered in sued.
Timing done with gates belts and new waterpump at 86k
Rear hatch doesn't open one of the latches is stuck.. no leaks.
He is located in Fort polk louisiana and is willing to drive to Houston Texas or new orleans. If not shipping can be covered at your expense. As I said everything listed had a receipt. You can text him at 5598625873 his name is connor. You can message me here for any questions as well.. text is the best option as he is a soldier and cannot take calls throughout the day
