Vehicle Marketplace - Old A place for Rennlist Members & Sponsors to sell their new & used vehicles.
Mark this thread as Unsold
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Cont. Porsche Models:
Mileage (numbers only please):
Color:
Price (no $ sign please):
Private or Dealer Listing:
Location (Region):
Transmission Type:
Parts Search
Keyword:
Category:
Private or Vendor Listing:
Location (Region):
Item Condition:
WTT: Street legal track 951 for 944/986/996
Old 02-24-2016, 11:17 PM
Mister Quickie
Mister Quickie's Avatar
Default WTT: Street legal track 951 for 944/986/996
Year: 1986
Make: Porsche
Model: 944
Cont. Porsche Models: 944 Turbo
Mileage (numbers only please): 184000
Options (Please check ALL which apply): Foglamps, Power Windows
Color: Yellow
VIN: WP0AA0956GN152538
Price (no $ sign please): $0
Private or Dealer Listing: Private Listing
Location (Region): NorthEast
Body Style: Coupe
Transmission Type: Manual - 5 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Turbo
Stereo System: None
I want to change the color of the car to green and the red interior isn't a match. It's in great shape and I'll drive it out to meet someone. Interested in either trading down to a 944 NA or trading up to a 986/996 NA.
With recent responsibilities I will neither be able to complete the mods for the track (suspension and hooking up Vitesse boost solenoid in order to control boost per user specified settings. Right now I just have a coupling connector on there so it doesn't go over 10 lbs boost) nor be able to take it to the track with any regularity.
I kept a log of most things (below). I haven't included minor things. This is neither a garage queen nor a show car, there are imperfections in the paint but no dings or dents and there's a crack in the winshield and the wipers work sporadically. I can take and post more pictures upon request. Passed VA state inspection April 2015 (with current setup), no rust, have spare keys. Below is the log, prior to 7/13 it was maintained by SSI in MD:
I drive the car at least once per week. I prefer to do the drive on the highway in order to get the speed and rpms up and the battery charged. Sometimes I'll drive it to work in DC and traffic is horrendous and it doesn't overheat.
Anything listed under 2007-2013 was done by SSI and transcribed by me from the paper invoices. There was a ton of work done but I only transcribed the more notable items.
While at Syracuse Porsche (2013) it got a new set of tires and there's less than 5000 miles on them since.
In April 2015 it got a full inspection by RPM and mechanically it's solid. Happy to meet at a shop for inspections.
btw the wheels are Fiskes and it has an Autopower rollbar in it now
Date Description
1/16/2016 Exhaust (still have stock exhaust): Cat delete, muffler, delete: 10' 2.75" ID pipe 2.75" OD downpipe
9/28/2015 Right Rear Tail light bulb holder assembly
9/5/2015 Lucas Oil Stabilizer
9/4/2015 Tire air
9/3/2015 Oil/Oil filter change
8/19/2015 Wiper motor relay replacement
7/19/2015 Mirror screws
7/19/2015 Powr Steering fluid flush
6/6/2015 Upper Strut Tower Brace
5/29/2015 Push-button start
5/18/2015 Air-Oil Separator, new fuel rail bolts (4x 6M 1.0P 12mm), new intake bolts (8x 8M 1.25P 35mm), DME temp sender, Gauge temp sender, Oil/Oil filter (Mahle) change
4/28/2015 AC Water drain hose
4/12/2015 New battery, battery disconnect switch
3/21/2015 E-brake delete, new starter
1/20/2015 Slave cylinder flush, Water temp gauge using radiator hose adapter 38mm, cabin filter
12/14/2014 Brake Pads (World Brake Resources DTC 608-03WBCD608-7326 201990), Brake fluid flush, Sensor wires (PEX WK12 SKU 296526)
11/30/2014 Rotor, distributor cap, cables, plugs; brake pads (4), brake pad sensors (2), brake fluid change
10/31/2014 Transmission fluid change
9/23/2014 4 wheel alignment
9/15/2014 Short Shift kit
9/15/2014 Both front lower steel control arms and (Weltmeister) bushings
8/15/2014 Oil change, lucas oil stabilizer
8/6/2014 Fuel injector cleaner
8/6/2014 Tail light seals
8/6/2014 A/C recharge, sealant
6/10/2014 P951: Door seal
6/10/2014 Window scraper
5/31/2014 Ignition bypass
5/30/2014 P951: Spare Keys
5/28/2014 Diaphram, diverter belt, oil pan seal leak
3/14/2014 P951: charging system check
3/1/2014 New thermostat
3/1/2014 Radiator flush
3/1/2014 New Fuel Lines
3/1/2014 Replaced Fuel tank with pressure tested used fuel tank
3/1/2014 Adjusted timing/cam belt
3/1/2014 Replaced alternator with remanufactured Bosch 120A alternator
1/1/2014 Radiator plug
1/1/2014 Replace right door seal
1/1/2014 Replace Right window seal
1/1/2014 Locking lugnuts
Syracuse Porsche:
7/2013-12/2013 Vitesse Stage 3R Turbo (Vitesse chip, 80lb Siemens injectors, larger turbo, boost solenoid)
7/2013-12/2013 Interior delete
7/2013-12/2013 1/2 shaft kits
7/2013-12/2013 Fire extinguisher
7/2013-12/2013 Front strut brace
7/2013-12/2013 Go over entire car: replace worn hoses, clamps, etc
7/2013-12/2013 Headlight delete nose piece
7/2013-12/2013 High pressure fuel pump
7/2013-12/2013 Hood scoop
7/2013-12/2013 New oil pan
7/2013-12/2013 Eagle GT Z-rated tires
7/2013-12/2013 Oil change
7/2013-12/2013 Oil intake breather with reducer
7/2013-12/2013 Power steering hose
7/2013-12/2013 Racing seats, seat brackets, seat slider
7/2013-12/2013 Repaint exterior
7/2013-12/2013 Repaint interior
7/2013-12/2013 Sunroof delete
7/2013-12/2013 Tune up
7/2013-12/2013 Vacuum line
7/2013-12/2013 Waste gate line
7/2013-12/2013 Rear wiper delete
SSI:
12/20/2010 Parts: "Rod Bearing Set" $162.87, Labor: "(Combination) CONNECTING ROD BEARINGS - Replace - One"
10/1/2007 Parts: "Rod Bearing Set" $111.47, Labor: "(Combination) CONNECTING ROD BEARINGS - Replace - All"
2007-2013 Engine or transaxle mount - Turbo - Both, Engine
2007-2013 Oil pan gasket
2007-2013 Power steering pump drive belt
2007-2013 Repack front wheel bearing
2007-2013 Climate control blower motor resister
2007-2013 Power steering hose - [Includes: Bleed system]
2007-2013 Rear hatch
2007-2013 Replace all hoses to crank case control line
2007-2013 Replace all hoses to idle control valve
2007-2013 A/C System - Complete Charge
2007-2013 Balance shaft bearing housing
2007-2013 Condensor
2007-2013 Control arm bushing [Includes: R&I lower control arm]
2007-2013 Door handle - Outer, Each
2007-2013 Front engine oil cooler behind bumper
2007-2013 Left & right swaybay bushings
2007-2013 Power steering pulley & belt
2007-2013 Reseal oil filter housing to block
2007-2013 Right tie rod assembly
2007-2013 Weld in left & right rad support & install radiator, Includes R&R of front bumper cover, header panel & intercooler, both front head lights
2007-2013 Clutch master cylinder [Includes: Bleed system]
2007-2013 Clutch slave cylinder [Includes: Bleed system]
2007-2013 Cam tower gasket
2007-2013 Clutch master cylinder hose
2007-2013 Right brake light sensor
2007-2013 Trunk hatch switch
2007-2013 Gas tank filler neck cover
2007-2013 Shift lever & socket
2007-2013 Door wiring harness plugs
2007-2013 Exhaust manifold [Includes: replace gaskets]- Turbocharger
2007-2013 Left window switch
2007-2013 Wiper & washer switch
2007-2013 Connecting Rod bearings - all
2007-2013 Spark plug wire set
2007-2013 Clutch kit
2007-2013 Clutch release arm
2007-2013 Crankshaft oil seal - Turbo, standard trans - rear
2007-2013 Hood shocks
2007-2013 Machine flywheel
2007-2013 Hood latch release cable
2007-2013 Strut assembly
2007-2013 Driver side door stop
2007-2013 Hatch seal
2007-2013 Heater control flap drive motor
2007-2013 Rear hatch locks
2007-2013 Transaxle assembly
2007-2013 Camshaft housing - turbo
2007-2013 Crankshaft oil seal - - Turbo - Front
2007-2013 Cylinder head gasket set
2007-2013 Differential side seal
2007-2013 Disc rotor, rear both
2007-2013 Engine Seal Kit
2007-2013 Four wheel alignment adjustment
2007-2013 Horn assembly -
2007-2013 Left & right balance shaft seals
2007-2013 Left & Right steering rack boots
2007-2013 Power mirros
2007-2013 Stabilizer bar bushing
2007-2013 Timing Belt
2007-2013 Timing Belt Tensioner
2007-2013 Water Pump
Mister Quickie is offline
Old 02-25-2016, 02:03 AM
vanishisam
2nd Gear
vanishisam's Avatar
if only i had enough cash to add with my Na to bring it to that level. clean car and good luck with sale!
vanishisam is offline
Quick Reply: WTT: Street legal track 951 for 944/986/996
