Mark this thread as Unsold
Porsche 944 turbo
PORSCHE 944 TURBO NEW TURBO, SPORT SEATS, tons of bolt-ons.
Year: 1987
Make: Porsche
Model: 944
Mileage (numbers only please): 160000
Options (Please check ALL which apply): Sunroof
Color: White
VIN: WP0AA2594HN151689
Price (no $ sign please): $3600
Private or Dealer Listing: Private Listing
Location (Region): SouthEast
Body Style: Coupe
Transmission Type: Manual - 4 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: AM-FM CD
I've owned the car since 2008. My uncle owned this car 10 years prior to me.
I took very good care of this car.
Had a small fire that didn't burn very hot. When it ran It I was noticing a small tic..tic..tic when I was low on oil, the spark plug closest to me always fowled first. Other than that the car ran like butter. Always put 93, and Lucas fuel lubricator religiously. (this was about 60k after rebuild)
After buying everything again wire harness, brand-new computer, all new sensors, oil pump, the car hasn't been able to run longer than a minute. I have replaced the top end of the motor, including all the reservoirs and mass airflow.(Removed for engine work) The car has a clean title. The car does not need anything but a motor rebuild ( just guessing it may not need a full rebuild) and paint. The turbo has less than 2,500 miles on it. (Thermal coated) sounds fantastic at 16psi.
The praise and compliments from this car are insane.
7272598745 - James
This car has quite an extensive parts list: all have been installed within 2 1/2 years Excluding sensors and computer(2-3 months) And buying the same Parts that were destroyed. Everything is there and nothing is missing.
(forgetting some things) PARTS:
Brand-new DME, Dark tint, Custom fiberglass nose, Custom 944 door sills, Custom fiberglass side skirts, Very expensive front splitter, 968 side mirrors, 968 doorhandles, 968 spoiler, Clutch master cylinder, MSD ignition, aluminum blow off valve, duel port wast gate, crossmember, Custom turbo floor mats, fire extinguisher, wide band air fuel ratio gauge, digital fuel mapping, K&N air intake system, Aluminum gauge bezels , sun visors, MOMO pedals, shifter, and steering wheel, short shift kit( upholstered shifter), carpet all around, 13 speaker sound system (very costly), genuine Porsche sport seats (very rare), fuel lines, fuel pressure regulator, koni adjustable shocks, 3'' Stainless steel magna-flow exhaust (sounds mean), Lindsey racing chips (Also have stock chips), injectors 55ibs , wires, Timing belt, water pump, Steering rack, ac compressor , brakes, slotted and drilled, stainless brake lines , wheels, larger turbo,(Super 53 T3 water oil cooled),adjustable boost inside cabin Most of the weatherstripping is brand new, Crankshaft rpm pulse sensors, All-around new brake sensors, and basic maintenance, Constant oil changes.
