Vehicle Marketplace - Old A place for Rennlist Members & Sponsors to sell their new & used vehicles.
Mark this thread as Unsold
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Cont. Porsche Models:
Mileage (numbers only please):
Color:
Price (no $ sign please):
Private or Dealer Listing:
Location (Region):
Transmission Type:
Parts Search
Keyword:
Category:
Private or Vendor Listing:
Location (Region):
Item Condition:
1991 964 C2 Black/Linen
Old 04-10-2015, 11:06 PM
mike9186
mike9186's Avatar
Default 1991 964 C2 Black/Linen
Year: 1991
Make: Porsche
Model: 911
Mileage (numbers only please): 105000
Options (Please check ALL which apply): Airbags, Air Conditioning, Alarm System, Antilock Brakes, Cruise Control, Foglamps, Power Brakes, Power Door Locks, Power Steering, Power Windows, Sunroof
Color: Black
VIN: WP0AB2969MS411375
Price (no $ sign please): $38000
Private or Dealer Listing: Private Listing
Location (Region): NorthEast
Body Style: Coupe
Transmission Type: Manual - 5 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: AM-FM CD
1991 Carrera 2 Coupe. Black with Linen interior. 5-speed. Overall very clean inside and out. Original paint is in exceptional condition but there are some scratches on both front and rear bumpers and some highway rock chips on the hood but no dents or dings on the body. Weekend car that lives in a weekend house garage and never sees weather. Tons of service records dating back to original owner. Comes with original airbag steering wheel and catalytic converter (I will reinstall either upon request). Upgrades include 17" Cup I wheels, Steve Wong Chip, Cat bypass and primary bypass, Bilstein HD Shocks and H&R Green Springs, 4-piston rear brake calipers. New Steering rack installed 4/15. Comes with air pump, car cover, and extra set of seats. 3k Miles on Continental ExtremeContact DW tires. This car gets compliments every time I take it out. Located in The Hamptons, NY.
$38k
Last edited by mike9186; 05-18-2015 at 05:13 PM. Reason: Added link to Photo Album
mike9186 is offline
Old 05-18-2015, 03:08 PM
mike9186
mike9186's Avatar
Bump for Reduced Price.
mike9186 is offline
Old 05-21-2015, 01:57 PM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,635 Likes on 2,318 Posts
pm u
call me
mooty is offline
Old 05-21-2015, 03:12 PM
kevgentile
kevgentile's Avatar
Sent you a message, thanks
kevgentile is offline
Old 05-21-2015, 05:29 PM
mike9186
mike9186's Avatar
I've been getting a lot of inquiries about the car and a lot of similar questions about maintenance and condition. Here is a list of all the work I've done on the car since 2010. I am also posting on Rennlist and Pelican so I apologize if this looks repetitive.
1. Last Valve adjustment @ 94k
2. New Plugs, coils, distributor caps and rotors, coils and plug wires in 2011
3. Fuel Filter Replaced 2010
4. Steve Wong Chip (93 Octane and Cat bypass)
5. Cat bypass installed (still have original Cat)
6. 4-piston brake calipers installed in rear (also added the correct proportioning valve)
7. Chain Housing door and tensioner gaskets replaced
8. Dual Distributor belt replaced 3 years ago
9. Replaced original suspension with Bilstein HD's and H&R Green Springs
10. Front Cult Werk Splitter added summer 2013. Front fascia 'Smile' straightened
11. CUP 1 replica wheels added 2014
12. Intake plenum removed and cleaned
13. Gear box oil replaced every 2 years. Currently has Delvac in it
14. Clutch Master and Slave cylinders replaced 3 years ago
15. Fan and alternator belts replaced last year
16. Oil cooler ballast reistor replaced in 2012
17. A/C ballast resistor replaced 2013
18. Front rotors and pads replaced in 2012
19. Headlight housings cleaned and lamps replaced in 2012
20. Shift tube gasket replaced and shift rod ballcup replaced.
21. 1 failed HVAC vent servo replaced in 2012
22. Brake's bled every 2 years with ATE SuperBlue or Pentosin.
23. Replaced Shift boot with newer leather boot
24. Replaced O2 sensor in 2013
25. Replaced Odometer gear in 2010
26. Distributor Vent Kit installed in 2012
27. New Interstate Battery installed in 2013
28. Motor mounts replaced with 993 mounts in 2012
29. Bought tire inflator but still missing factory toolkit
30. Main oil return hose replaced
31. Leaky Steering rack replaced with reconditioned unit. New rack boots, bushings and tie rods also installed. Still have original rack
32. Front control arm bushing replaced with Chris walrod Urethane
33. Front and rear sway bar bushings replaced with Powerflex Urethane. Front drop links replace with new OEM and rear drop links replaced with Tarett monoball adjustable drop links
34. Installed Momo Mod07 leather Steering wheel and matching hub. Still have original Airbag wheel.
35. Stereo replaced in 2014 with Blaupunkt Toronto 420 BT. Rear shelf speakers also replaced.
36. Continental ExtremeContact D/W tires fitting in spring of 2014. Have approx 3k miles on them.
37. Front Strut Brace installed.
38. Brand new rear Bilstein HD shocks installed 4/15 because driver’s side failed and was replaced under warranty.
39. New OEM Door Tweeters installed.
40. A/C Converted to R134 some time in the past. I add a can of refrigerant every Spring. Could use a proper evacuation and fill.
mike9186 is offline
Old 05-22-2015, 11:39 AM
speedbagger
speedbagger's Avatar
beautiful and ready to drive. nice record keeping and maintenance. glws.
speedbagger is offline
Old 05-22-2015, 03:49 PM
mike9186
mike9186's Avatar
Car is SOLD. It will be going to a great new owner.
Thanks Rennlist!
mike9186 is offline
Quick Reply: 1991 964 C2 Black/Linen
