Mark this thread as Unsold
Porsche 944 (SP1 Candidate)
Year: 1983
Make: Porsche
Model: 944
Cont. Porsche Models: 944
Mileage (numbers only please): 99999
Color: Black
VIN: WPOAA0941EN454503
Price (no $ sign please): $5500
Private or Dealer Listing: Private Listing
Location (Region): Midwestern
Body Style: Coupe
Transmission Type: Manual - 5 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: None
-2.5L
-944S2 Oil Cooler and Oil Cooler Housing
-Quick Change Oil Filter Cartridge System
-Updated Injectors
-Newer MAF System
-Original MAF System included as spare
-Magna Floor Muffler
-Factory Header & Pipes
-New High Capacity Radiator with Fan
-New Water Tank
-New Hoses
-New Belts
-New Rollers
-New Seals
-New Water Pump
-New Fuel Pump & External Mounting Kit
-New Fuel Filter
Transmission
-Standard 5-sp transmission
-Serviced and Updated fluid
-Newer Clutch
-New Slave Cylinder
-New Master Cylinder
-Air conditioning compressor removed
Suspension/Brakes
-Weltmeister-350# front springs
-Weltmeister--sway bars, 28mm-Front
-Weltmeister--sway bars, 22mm-Rear
-Weltmeister--Tubular torsion bars, 28mm Rear (ride height lowered 1")
-Weltmeister-Strut brace
-KoniShocks -8631-1038, Sport Adjustable -Front
-KoniShocks -1209, Adjustable three settings --Rear
-Front height adjustable spring perches
-Adjustable camber plates
-Steel Arms with new Ball Joints & Tie Rods
-Manual Rack -- Serviced & Updated
-Corner Balanced for 175LBS
Brakes
-Carbotech brake pads front and rear
-Braided stainless steel brake lines (F&R)
Rims / Tires
-1 set of late offset, 15x7 Porsche OEM "Cookie Cutters" rims, black, w/ Hoosiers
Interior
-Fully-stripped interior including heater, fan, etc. removed, doors gutted and cored, all carpet, seats, headliner, padding, sound-deadening, insulation removed
-Factory Seats
-Momo Steering Wheel
-Removable door window glass for Hauling and Storage
Body
-Head Lights Removed
-Good Paint
-Some Rust in Floor due to typical front leaks into passenger compartment
All parts are new and work was completed in June 2013 -- only 1 Porsche DE event.
The downside to the car is that the front of the car grazed the wall at the 1 DE event. The front bumper is pushed in and a couple of the panels are wrinkled. It is an easy fix, but I am working to complete a 914 Historic Race.
Lot's of pictures available detailing the car.
Would make a great SP1 Race Car.
$5,500 best offer!
952-240-6023
