Mark this thread as Unsold
FS: 1999 E36 M3 track car - very clean, very well built
Year: 1999
Make: BMW
Model: M3
Mileage (numbers only please): 89000
Color: Silver
Price (no $ sign please): $15000
Private or Dealer Listing: Private Listing
Location (Region): NorthWest
Body Style: Coupe
Transmission Type: Manual - 5 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: AM-FM Cassette
I only tracked it for 1 season (last year), a total of 8 days, about 800 miles on track. Needs nothing, runs perfectly, it is turn-key.
I've documented the entire build on a spreadsheet. About $21k invested in parts and maintenance. The below list of parts are 1 yrs old and 800 miles used (everything is LIKE NEW):
Suspension (Front):
- TC Kline DA coil overs with 600/700 springs
- TC Kline camber plates monoball race
- BMW Xbrace
- New OEM front control arms
- Bimmerworld Delrin FCAB's
- Bimmerworld adj sway bar end links
- Front subframe reinforced Turner reinforcements
- Hotchkis 35mm adj front sway bar
- Rogue race brace front strut bar
Suspension (Rear):
- Hotchkis 24mm adj rear sway bar
- Hotchkis rear sway bar adj end links
- Hotchkis rear sway bar reinforcement kit
- TC Kline rear shock mounts, monoball
- TC Kline race RTABs, monoball
- Turner adj rear camber arms
- Turner solid aluminum rear subframe bushings
- Turner solid monoball inner upper control/spring arm bushings
- Turner solid aluminum diff mount bushings
- OEM outer upper and outer lower trailing arm ball joints
- AKG RTAB pocket reinforcements
- Mason Engineering 3 piece steel rear strut bar
Engine:
- Bimmerworld solid aluminum engine mounts
- S54 dual pick up oil pan and pump conversion kit
- Oil pump nut safety wired and loctite
- UUC RSC36 exhaust
- Spal 16inch puller fan
- ASC traction control delete
Transmission/Diff:
- Bimmerworld solid aluminum transmission mounts
- Front diff bolt upgraded with 10.9 grade
- CAE Ultra shifter
- UUC DSSR
Brakes:
- Stoptech ST40 332mm front BBK
- Castrol SRF brake fluid
- Stoptech stainless brake lines
- Powerslot rear brake rotors
- Rear calipers rebuilt brass caliper guide rod pins
- PFC01 brake pads (50% life remaining)
Wheels/Tires:
- Kosei K1 17x8.5
- Hoosier R6's 245/40 (corded)
- Apex ARC8 17x9
- Nitto NT01 255/40 (20ish heat cycles)
- Turner wheel studs
- Turner race lug nuts
- H&R 12mm hub centric front spacer
Body:
- Motion Motorsports front aluminum under panel
- Motion Motorsports radiator baffle for under panel
- Turner fog light blank covers
- S2R Tuning carbon fiber sunroof delete panel
Interior/Safety:
- VAC race seat kits (floor mounts & side mounts)
- VAC anti-sub mounts
- VAC lap belt mounts
- Recaro SPG-XL (pair)
- TC Kline bolt in roll bar
- Sparco 6pt harnesses (pair)
- Turner tow hooks front and rear
- CAE Quick release steering wheel
- Sparco 345 Competition steering wheel black suede
All the below maintenance items addressed last Apr 2012, 8 track days. Oil changes obviously were done more frequently!:
- Transmission fluid changed OEM
- LSD diff oil OEM
- Engine oil Rotella T6
- Coolant OEM antifreeze
- Air filter OEM
- Power steering fluid Redline D4 ATF
- Drive Belts OEM
- Radiator VSL aluminum
- Water pump Stewart metal impeller
- Thermostat BEHR 88deg
- Aluminum thermostat housing
- Coolant hoses all replaced with OEM
- Oil filter housing gaskets replaced with OEM
- Tensioner pulley, idler pulley, accessory belt tensionsers, all replaced with OEM
- Vanos oil line replaced with OEM
- Coolant hoses replaced OEM
- Power steering reservior, hoses, and clamps all replaced with OEM
- Oil pan gasket replaced with OEM
- Rear wheel bearings replaced with OEM
- CDV clutch delay valve removed and clutch slave cylinder bled
Please no trades, no parting out as I am going to sell it complete. PM me for more details, pictures, videos.
$15,000 for everything includes spares, extra set of wheels. I don't have the stock parts anymore and some of the pictures below show the doors fully in tact. I've since gutted the doors so that they are the bare shell, no door windows, no power windows, etc...
![](https://dl.dropboxusercontent.com/u/49555538/M3%20for%20sale/Photo%20Jul%2031%2C%2012%2014%2006%20PM.jpg)
For some reason I did not get the pm. shoot me an email benhchang@hotmail.com with your telephone number so that we can chat now.
deposit taken! thanks for all the interest everyone... i'm sad to see her go.
for those that contacted me interested in buying the car, i will keep your contact just in case!
GT3 player par excellence
damn fast sale
