Mark this thread as Unsold
87 Porsche 944 Turbo Track Car
Year: 1987
Make: Porsche
Model: 944
Cont. Porsche Models: 944 Turbo S
Mileage (numbers only please): 0
Color: Grey
Price (no $ sign please): $23000
Private or Dealer Listing: Private Listing
Location (Region): NorthEast
Body Style: Coupe
Transmission Type: Manual - 5 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: None
Engine:
rebuilt 2.5 Turbo S motor.
Rebuilt Turbo from Lindsey Racing
Every hose replaced last fall (vacuum, coolant)
New timing belt water pump
Stock Turbo S ECU and DME
Dyno'ed at 235 RWHP 244 Torque
Stock boost pressure
Oil changed every event
Full 3" Lindsey race exhaust
Transmission:
Fully built 944S2 gearbox with shortened turbo 5th gear
Brand new Guard limited Slip
new stock axles
Locking axle fasteners
Kokelln short shifter (both on the transmission and in the car)
Gear oil changed every event
Solid trans mounts
Suspension:
3 way adjustable JRZ struts and shocks with external reservoirs. No races since rebuild (have receipts)
Kokln camber plates
1100 lb springs rear
900 lb springs front
Every bushing replaced with Racers edge solid bushings
Bump steer kit
Racers Edge control arms
Chassis:
Modified Safety Device roll cage
Brand new ground FX by AJ Hartman. Front splitter and rear Carbon Fiber wing with 2 sets of uprights. 1- Legal for PCA 2-Legal for NASA GTS-3
Lexan rear hatch
3 Piece cross member
2 piece cross over pipe(oil pan off in 45 min)
Brand new Momo steering wheel with quick release
AEM boost gauge
Current center and window nets
Still has factory door skins
factory power windows
Factory defrost and heat still in place
Factory rear Euro bumper(not cheap fiberglass)
Wheels:
2 sets of factory BBS 18" Magnesium wheels
18X9's Front
18X11's Rear
Brakes:
GT3 6 Piston front calipers with 350MM Rotors
Factory Turbo S rear calipers with slotted rotors
Performance Friction front and rear pads with one event
Braided lines
Car weighs 3040 with driver
Car just ran a :58:61 on old tires at Limerock Park this past tues 4/9/13
Car is truly dialed in and ready to race.
Please call with any questions
646-504-3348
