Mark this thread as Sold
914 -6 track car
Year: 1974
Make: Porsche
Model: 914
Mileage (numbers only please): 9999999
Color: black
VIN: 4742904407
Price (no $ sign please): $32000
Private or Dealer Listing: Private Listing
Location (Region): SouthEast
Body Style: Targa
Transmission Type: Manual - 5 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Carbs
Stereo System: None
2.8 engine (2.0 case) built by Motor Meister, s rods ,cams, lite head work, low time on the engine, pulls great, no smoke, no leaks.
HamFab
CAMBER PLATES
FT & RR SWAYBAR HEIM JOINT set up
COILOVER SUSPENSION
Koni front /REAR BILSTEIN
WILWOOD RACING BRAKES (Superlite cal, rotors 12" X 1.25 F 12" X .81 R )
Titlon three pedal assemblies , reservoir, balance bar,
5SP 901 CLOSE RATIO TRANS W/ COOLER AND PUMP
DRY SUMP/ PETERSON TANK ( 3 gal )
AN FITTINGS AND LINES
(7) 16X10 WHEELS
100MM STUD
KIRKEY SEAT
5 point BELTS (set up for and comes with second Kirley seat)
EECTROMOTIE ENGINE AUTOMETER SPORT COMP MONSTER TACK W/SHIFT LIGHT, OIL PSI, OIL TEMP, VOLTS GAUGES
15 GAL FUELSAFE GAS TANK
SUPERTRAPP EXHAUST AND HEADERS.
DRY WEIGHT 1886 LBS. SHERIDAN SUPER WIDE BODY GRAFTED ONTO CAR BY HAMFAB
This car was built to professional racing standards with only autocross and DE time. It is capable of handling far more engine...... if you are considering running a 914 6.....come look at this car to use as you bench mark. this is a dream 914 6, not a weekend warrior fix and repair project.
