Mark this thread as Unsold
Modded 944 turbo
Year: 1987
Make: Porsche
Model: 944
Cont. Porsche Models: 944 Turbo
Mileage (numbers only please): 4000
Color: Silver
Price (no $ sign please): $7500
Private or Dealer Listing: Private Listing
Location (Region): NorthEast
Body Style: Coupe
Transmission Type: Manual - 5 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: AM-FM CD
Fresh motor less then 4,000 miles every seal and bearing replaced
Head rebuild-WIDE FIRE Head gasket
Water pump with all rollers 4,000 ago with Motor Rebuild
Spec Clutch
K27/6 Turbo Build by Motor Werks Racing
Custom Chip for turbo and motor By Motor Werks Racing
Lindsey Racing A/C DELETE BRACKET
NEW Timing belt and balance shaft No miles
Lindsey Racing Billet Non-Adjustable Style BYPASS VALVES
MSD BLASTER 2 ANTI-VIBRATION COIL
BOSCH FUEL PRESSURE REGULATOR 3.0 BAR
Lindsey Racing’s one piece Solid Transmission Mount
Black Cam tower and Chrome Powder Coated Intake Manifold
IDLE STABILIZER / VENTURI DELETE HOSES 944T
Lindsey Racing BOOST ENHANCER
New CRANK IMPULSE SENDER (reference sensor) X2
New THROTTLE POSITION SWITCH (TPS)
New TEMP SENSOR DME (Coolant Temp Sensor)
New Low Temp RADIATOR FAN SWITCH
New ALTERNATOR
Header Wrapped in Thermo-Tec Standard Header Wrap (original brown)
Optima Red Top Battery
New Battery Cables
New Starter
Heat Shield For Hot Side of Turbo
Lindsey racing A pillar Gauge Pod with Autometer Boost and Water Temp Gauges
Koni Adjustable Shocks Front/Rear with Front Weltmeister 250lb Lowering Springs
Zimmermann Cross Drilled Rotors Front and Rear
Super Blue Brake Fluid
Stainless Steel Braided Brake Lines
C-2 Turbo Wheels F=245 R=255(your choice of rims)
BBS 5 Spoke Two Piece Wheels, Carbon Fiber Look(your choice of rims)
MOMO Steering Wheel
Kenwood speakers
Pioneer Head Unit
Bad:
Dash is Cracked
Rear Driver Quarter panel has dent
Front Pass Fender Scratched
Sun roof panel is faded and not 100% match to car col
$8,500 OBO
Price drop 1/19/12 to $7,500 OBO(shoot me a offer I cant refuse I want to finish my race car for this coming season.)
View site for Pictures and Video:
http://jeff951.netvenommedia.com/
