Mark this thread as Unsold
FS: 944 S2 fully developed
Year: 1989
Make: Porsche
Model: 944
Cont. Porsche Models: 944S2
Mileage (numbers only please): 23000
Options (Please check ALL which apply): Antilock Brakes, Power Brakes, Power Steering, Traction Control
Color: RS green
Price (no $ sign please): $17900
Private or Dealer Listing: Private Listing
Location (Region): NorthEast
Body Style: Coupe
Transmission Type: Manual - 5 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: None
NASA GTS2, GTS3
2775# with 1/2 fuel and 215# driver
Body:
Straight body, all steel panels, no headlights, filler panel installed
Retro RS green exterior, RS orange interior, trim and numbers / letters
Front fog lights removed
Gutted doors, w/ removable Lexan side windows and Lexan rear hatch
Euro rear bumper
Custom lightweight nose with 2010 front spoiler splitter
All carpet and all glue removed, interior re-sprayed 2010
Aluminum driver floor mat
Engine & brakes:
2009 engine installed with 25k original miles
2011 total top-end rebuild, with new valve springs, valve guides, head gasket, timing belt, benchflow, by Michael Mount
Behe dyno-tune with multiple ECU options (for class)
2011 engine totally gone over, new ignition parts, fuel pump, lines
New rod bearings 3/10
Lindsey oil pan baffle
Racer’s Edge (Stahl) header, muffler and pipe
2011 Racer’s Edge racing clutch and LWF
Turbo S brakes, new pads (9-10) with 2011 Quick-bleed valves
2010 Autometer tachometer with shift light
2010 new stock temperature gauge
2010 new fuel gauge sender
SS brake lines F&R
External cone filter w/ forced air
Trans:
Rebuilt 4/10 S2 gearbox w/ factory LSD, short (Turbo 5th), clean synchros, perfect shifts
Solid trans mounts
Safety:
2010 custom Cage-This roll cage, extremely strong and safe, easy entry, flush with pillars, cross beams, extra bracing at mounting points
CDOC 8 lb 6 nozzle fire system, with driver access and exterior pulls
Scroth Hans 6-point belts, current
Sparco EVO seat
Momo 13.5 suede wheel, with quick release
New in 08 side window and center nets
New battery, 5/10
NASA, SCCA and PCA log books current
Suspension & Wheels:
Camber plates
New bump-steer kit with fresh alignment (5/11) and corner balance
Moton Club Sport external adjustable shocks
New 2011 Hypercoil 750# front, 1000# rear springs, perfectly balanced suspension
Racers Edge solid bushings and front control arms
No torsion bar, carrier removed cleaned and painted; delrin bushings installed
Racing dynamics strut-tower brace
Enkei race wheels 18x8 and 18x9, 1 set, with R-6’s
Factory front sway bar M030 26.5mm with Delrin bushings
Factory M030 rear bar with Delrin bushings
No rubber remaining in suspension
The car is complete, fresh, fast and reliable, totally up to date and ready to race. One of the best developed, most complete S2’s in the country (over $9000 in updates in 2011, receipts available)
2011: 1st NASA NJMP Lightning, 2nd PCA LRP
LRP: 1.00.3
NJMP Lightning: 1.15.2
2010 Monticello Motor Club: 2:42.14 (Before rebuild)
Please contact: Ron Cohn
ronaldcohn@gmail.com
914-474-4151
Yes, it is still available, although one party is inspecting it today and I have a backup offer. I have never run it in an SCCA race although it has an SCCA logbook. I believe it would run in ITR.
I will watch the thread to see if you close your current offer...
If you have additional pics could you send them to joshua@upmentors.com ?
Thanks,
Joshua
Thanks,
Joshua
