Mark this thread as Unsold
1996 993 Midnight Blue/Grey C2
Year: 1996
Make: Porsche
Model: 911
Cont. Porsche Models: 911
Mileage (numbers only please): 73000
Options (Please check ALL which apply): Airbags, Air Conditioning, Alarm System, Antilock Brakes, Cruise Control, Intermittent Wipers, Leather Seats, Power Brakes, Power Door Locks, Power Steering, Power Windows, Sunroof, Traction Control
Color: Midnight Blue
Price (no $ sign please): $33500
Private or Dealer Listing: Private Listing
Location (Region): Texas
Body Style: Coupe
Transmission Type: Manual - 6 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: AM-FM Cassette
Pics: http://s851.photobucket.com/albums/a...911%20Carrera/
Below is all the service/maintenance history I have:
Oil and Filters Changed - April 28, 1997 @ 10,521 miles
New Tires (Sewickley Porsche) - April 28, 1997 @ 10,521 miles
Wiper Inserts Replaced (Sewickley Porsche) - April 28, 1997 @ 10,521 miles
New Sunroof Gasket (Sewickley Porsche) - April 28, 1997 @ 10,521 miles
15k Service (Sewickley Porsche) - March 27, 1998 @ 14,814 miles
New Tires (Sewickley Porsche) March 6, 1998 @ 14,539 miles
Oil and Filters Changed - May 18, 1999 @ 22,188 miles
Sunroof Repaired - May 18, 1999 @ 22,188 miles
Oil and Filters Changed - July 5, 2001 @ 31,101 miles
Oil and Filters Changed (Hennessy Porsche) - April 30, 2008 @ 56,008 miles
New Rear Spoiler Ribbon (Hennessy Porsche) - April 30, 2008 @ 56,008 miles
New Deck Lid Gas Strut (Hennessy Porsche) - April 30, 2008 @ 56,008 miles
New Hood Gas Strut (Hennessy Porsche) - April 30, 2008 @ 56,008 miles
60k Service (Hennessy Porsche) - July 10, 2009 @ 60,983 miles
Oil and Filters Changed (Mobil 1)
Pollen Air Filter Replaced
Spark Plugs Replaced
Wiper Blades Replaced
Transmission Fluid Changed
Oxygen Sensor Replaced (Hennessy Porsche) - July 10, 2009 @ 60,983 miles
Lower Valve Cover Gaskets Replaced (Hennessy Porsche) - July 10, 2009 @ 60,983 miles
Front Brake Pads and Rotors Replaced (Hennessy Porsche) - July 10, 2009 @ 60,983 miles
Brake System Flush (Hennessy Porsche) - July 10, 2009 @ 60,983 miles
V Belts Replaced (Hennessy Porsche) - July 10, 2009 @ 60,983 miles
New Rear Decklid Struts Installed (Hennessy Porsche) - July 10, 2009 @ 60,983 miles
While In My Care
_____________________________________________
New Lighted Key Cap with Remote Housing (OEM) (Roger Beasley Porsche) - September 28, 2009
New Michelin Pilot Tires (Costco Tire Center) - October 29, 2009 @ 64,712 miles
New Door End Cap and Door Lock Cap (OEM) (DIY) - November 5, 2009
Windshield Rust Repaired (Berli’s Body Shop) - November 12, 2009 @ 64,808 miles
New ROW M030 Springs (OEM) (Roger Beasley Porsche) - November 17, 2009 @ 64,935 miles
New Right Control Arm Cover (OEM) (Roger Beasley Porsche) - November 17, 2009 @ 64,935 miles
Four Wheel Alignment (Roger Beasley Porsche) - November 17, 2009 @ 64,935 miles
Oil and Filters Changed (Brad Penn 20w/50 and Mahle Filters) (Roger Beasley Porsche) - December 10, 2009 @ 65,532 miles
New Right Windshield Washer Nozzle and Check Valves (OEM) (DIY) - December 16, 2009
New Trunk Seal End Piece (OEM) (DIY) - December 21, 2009
New Battery (Optima Sealed) (DIY) - January 24, 2010 @ 66,573 miles
Installed Strut Brace (911chips) (DIY) - February 22, 2010 @ 67, 384 miles
New Distributor Caps and Rotors (OEM) (DIY) - April 3, 2010 @ 68,485 miles
New Rear Brake Pads (OEM) (DIY) - April 13, 2010 @ 68,819 miles
New Steel Wheel Lugs (OEM) (DIY) - April 20, 2010 @ 68, 936 miles
New LED Position Light Bulbs (DIY) - May 9, 2010 @ 69,207 miles
New Air Duct for Engine Cooling Fan (OEM) (DIY) - May 30, 2010 @ 69,322 miles
New Oval Door Cap on Driver Side (OEM) (DIY) - June 23, 2010
New Center Console Cup and Insert (OEM) (DIY) - July 7, 2010
New Drain Plugs in Luggage Compartment (OEM) (DIY) - September 30, 2010
Passed Safety / Emissions Inspection (Roger Beasley Porsche) - October 8, 2010
Custom Covercraft UVS100 Heat Shield (Covercraft) - October 8, 2010
Oil / Filters Changed (Brad Penn 20w/50 and Mahle Filters) (DIY) - October 18, 2010 @ 69,957 miles
18” Porsche Sport Design Wheels + New Sumitomo HTRZIII Tires (SoulSpeed Performance + DIY) - November 4, 2010 @ 70,250 miles
New Porsche RS Motor Mounts (OEM) (DIY) - December 6, 2010 @ 70,823 miles
Installed Wheel Locks (McGard) (DIY) - December 7, 2010 @ 70,823 miles
HID Low-beam Headlight Bulbs w Ballasts (DDM Tuning) (DIY) - December 15, 2010 @ 71,015 miles
New Air Filter (Mahle) (DIY) - December 15, 2010 @ 71,015 miles
Fresh Transmission Fluid (Mobil Delvac 75w-90) (DIY) - January 1, 2011 @ 71,212 miles
Brake Fluid Flush (ATE 200 DOT 4) (ProTech) - January 10, 2011 @ 71,338 miles
Clutch Fluid Flush (ATE 200 DOT 4) (ProTech) - January 10, 2011 @ 71,338 miles
New Pollen Filters (Mahle) (DIY) - January 11, 2011 @ 71, 353 miles
New Underpanel Pin and Springwasher (OEM) (DIY) - January 11, 2011
New Windshield with New Inner/Outer Seals (Pilkington Germany Glass w/ OEM Seals) (Safelite) - January 13, 2011
New Bumperette Mounts (OEM) (DIY) - January 22, 2011
New Slave Cylinder (OEM) (ProTech) - May 19, 2011 @ 72,031 miles
New Koni Sport Shocks (Koni) (SoulSpeed Performance) - June 3, 2011 @ 72,353
Fuel System Cleaned (Techron) (DIY) - June 3, 2011
New Fuel Filter (Mahle) (ProTech) - June 6, 2011 @ 72,681 miles
Oil / Filters Changed (Brad Penn 20w/50 and Mahle Filters) (ProTech) - June 6, 2011 @ 72,681 miles
