Mark this thread as Unsold
944S2 racecar
Year: 1989
Make: Porsche
Model: 944
Cont. Porsche Models: 944S2
Mileage (numbers only please): 23000
Options (Please check ALL which apply): Antilock Brakes, Power Steering
Color: RS Green
Price (no $ sign please): $19900
Private or Dealer Listing: Private Listing
Location (Region): NorthEast
Body Style: Coupe
Transmission Type: Manual - 4 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Other
Stereo System: AM Radio
NASA GTS2, GTS3
2800 with ¾ fuel and 215# driver
Body:
Straight body, all steel panels, no headlights, filler panel installed
Retro RS green exterior, RS orange interior, trim and numbers / letters
Front fog lights removed
Gutted doors, w/ removable Lexan side windows and Lexan rear hatch
Euro rear bumper
Custom lightweight nose with 2010 front spoiler splitter
All carpet and all glue removed, interior re-sprayed 2010
Aluminum driver floor mat
Engine & brakes:
2009 engine installed with 25k original miles
2011 total top-end rebuild, with new valve springs, valve guides, head gasket, timing belt, benchflow, by Michael Mount
Behe dyno-tune with multiple ECU options (for class)
2011 engine totally gone over, new ignition parts, fuel pump, lines
New rod bearings 3/10
Lindsey oil pan baffle
Racer’s Edge (Stahl) header, muffler and pipe
2011 Racer’s Edge racing clutch and LWF
Turbo S brakes, new pads (9-10) with 2011 Quick-bleed valves
2010 Autometer tachometer with shift light
2010 new stock temperature gauge
2010 new fuel gauge sender
SS brake lines F&R
External cone filter w/ forced air
Trans:
Rebuilt 4/10 S2 gearbox w/ factory LSD, short (Turbo 5th), clean synchros, perfect shifts
Solid trans mounts
Safety:
2010 custom Cage-This roll cage, extremely strong and safe, easy entry, flush with pillars, cross beams, extra bracing at mounting points
CDOC 8 lb 6 nozzle fire system, with driver access and exterior pulls
Scroth Hans 6-point belts, current
Sparco EVO seat
Momo 13.5 suede wheel, with quick release
New in 08 side window and center nets
New battery, 5/10
NASA, SCCA and PCA log books current
Suspension & Wheels:
Camber plates
New bump-steer kit with fresh alignment (5/11) and corner balance
Moton Club Sport external adjustable shocks
New 2011 Hypercoil 750# front, 1000# rear springs, perfectly balanced suspension
Racers Edge solid bushings and front control arms
No torsion bar, carrier removed cleaned and painted; delrin bushings installed
Racing dynamics strut-tower brace
Enkei race wheels 18x8 and 18x9, 1 set, with R-6’s
Factory front sway bar M030 26.5mm with Delrin bushings
Factory M030 rear bar with Delrin bushings
No rubber remaining in suspension
The car is complete, fresh, fast and reliable, totally up to date and ready to race. One of the best developed, most complete S2’s in the country (over $9000 in updates in 2011, receipts available)
2011: Win and second place
LRP: 1.00.3, Lightning: 1.15.2
Asking $19,900 OBO
Also available:
Spare S2 motor, Behe tuned, strong and reliable, ran LRP 1:00.9 lap in 2009
$3000
BBS Magnesium wheel set, the lightest available, bead-blasted and painted 3-11 ($800)
$3200
Can offer reasonable package deal for serious buyer
Please contact: Ron Cohn
ronaldcohn@gmail.com
914-474-4151
