My 32' ATC diary
maschinetheist (08-13-2024)
splurged on the 48" door tray and flip down bench!
![Name: Zkigsuv.jpg
Size: 379.7 KB](https://rennlist.com/forums/attachments/trucks-and-trailers/1353474d1683259829-my-32-atc-diary-zkigsuv.jpg)
inverter is here...it's a bit larger than I anticipated. for scale, the wheel on the truck is off a f350
![Name: Zkigsuv.jpg
![Name: NE1GK1Z.jpg
Size: 395.2 KB](https://rennlist.com/forums/attachments/trucks-and-trailers/1353475d1683259829-my-32-atc-diary-ne1gk1z.jpg)
Your MPG are similar to what I get, 10-11 depending on terrain. I pull with Ram 6.7 diesel dually and a 44' gooseneck loaded weight around 11,000 lbs. I get 15-16 MPG with a bumper pull 22' trailer.
been so busy lately. managed to make some progress with the trailer:
pulled down the tire and helmet racks which were secured with some suspect self tappers...
![Name: Qf3L824.jpg
Size: 201.5 KB](https://rennlist.com/forums/attachments/trucks-and-trailers/1352650d1683259317-my-32-atc-diary-qf3l824.jpg)
replaced with m8x1.25 rivnuts
![Name: DU76Ci9.jpg
Size: 218.3 KB](https://rennlist.com/forums/attachments/trucks-and-trailers/1352651d1683259317-my-32-atc-diary-du76ci9.jpg)
![Name: jHdQB0T.jpg
Size: 188.7 KB](https://rennlist.com/forums/attachments/trucks-and-trailers/1352652d1683259317-my-32-atc-diary-jhdqb0t.jpg)
![Name: Qf3L824.jpg
![Name: DU76Ci9.jpg
![Name: jHdQB0T.jpg
![Name: Q0L00BM.jpg
Size: 449.0 KB](https://rennlist.com/forums/attachments/trucks-and-trailers/1352653d1683259317-my-32-atc-diary-q0l00bm.jpg)
Installed the flip down bench this weekend. Because of the e-track, this is the lowest I could mount the workbench and it sits about chest level. I'm going to try it out and see if it's too high. If it's too high, I will just make a set of spacers so the bracket can sit over the e-track.
![Name: 4Ito3cR.jpg
Size: 457.8 KB](https://rennlist.com/forums/attachments/trucks-and-trailers/1352551d1683259263-my-32-atc-diary-4ito3cr.jpg)
![Name: 20uDoI8.jpg
Size: 503.0 KB](https://rennlist.com/forums/attachments/trucks-and-trailers/1352552d1683259263-my-32-atc-diary-20udoi8.jpg)
![Name: 2rgjkVB.jpg
Size: 796.4 KB](https://rennlist.com/forums/attachments/trucks-and-trailers/1352553d1683259263-my-32-atc-diary-2rgjkvb.jpg)
![Name: RnIDJIz.jpg
Size: 378.8 KB](https://rennlist.com/forums/attachments/trucks-and-trailers/1352554d1683259263-my-32-atc-diary-rnidjiz.jpg)
![Name: 4Ito3cR.jpg
![Name: 20uDoI8.jpg
![Name: 2rgjkVB.jpg
![Name: RnIDJIz.jpg
![Name: 88DuX9E.jpg
Size: 508.5 KB](https://rennlist.com/forums/attachments/trucks-and-trailers/1352555d1683259263-my-32-atc-diary-88dux9e.jpg)
You've got quite the project going there. Very nice!
Next up for me is to add a PVC strip door for the curb side door. I've chosen the yellow tint that is supposed to help ward off insects. The last time up at Thunderhill the flies were completely out of control. It was disgusting. We had to buy a few dozen fly strips at Walmart to even make it tolerable.
Original design for the 100x100 VESA mount.
![Name: hlNecFa.png
Size: 144.4 KB](https://rennlist.com/forums/attachments/trucks-and-trailers/1352480d1683259247-my-32-atc-diary-hlnecfa.png)
Thought about this some more and simplified everything. Two horizontal bars with stud holes 16" OC, and the 100x100 VESA holes.
![Name: hlNecFa.png
![Name: SnnTHPb.png
Size: 163.9 KB](https://rennlist.com/forums/attachments/trucks-and-trailers/1352481d1683259247-my-32-atc-diary-snnthpb.png)
