Ford F250 Brakes
Ford F250 Brakes
Hi. My 2013 F250's brakes have been feeling a little off so looking to play it safe and give the system a once over. Any recommendations for pads, rotors, fluid and brake lines? The truck is used almost exclusively for towing.
I have a 2012 250 crew longbed using stock pads etc. and they seem fine (with routine maintenance).
Are you unhappy with factory standard or just looking to improve?
Thanks Rick. I'm wondering whether the issue is routine maintenance related or me overtaxing the system. I'm towing less weight than you so stock is probably fine.
I have a 2013 F250 diesel also. I've only had to change the pads once and used the OEM's. They work fine to me. No need to overthink it unless you're trying to address / improve a specific issue.
WRONGLY ACCUSED!
What feels off? Lack of stopping power? Vibration?
I have an F350 and tow a 27 foot steel trailer. I use stock rotors and pads and haven't had a problem.
pretty much the same truck as mine. what load are you towing? my pedal was a little soft so I bled it and it's been great with OEM parts
