My Trailer Diary
Old 06-06-2017, 10:56 PM
  #616
24Chromium
24Chromium's Avatar
Originally Posted by zip465
Thanks for sharing Lar! Who made the tire cart?
www.irvansmith.com
They sell a bracket/shelf for the cart to hold a gas bottle. I've got that on mine as well. However, there is no good way to secure the bottle, so I suggest you have them weld on a bottle clamp to the cart. Same clamp as I use to hold the nitrogen bottle in the trailer.
Originally Posted by FFaust
Cool hangars indeed. Where did you find those?
Yep, everybody wants them! Sadly, no longer in production.
Originally Posted by DTMiller
Hi, I'm 24chromium, you may know me from such threads as My Trailer Diary or Holy **** Did You See My Toolbox Drawers? I'm here to talk to you about awnings, carts, cabinets and ladders useful for cleaning trailers.
I most certainly have OCD. And CRS.
Originally Posted by TRAKCAR
Bottle of Jack Daniels was hiding..
Indeed. Did you notice that the paddock was completely devoid of all humans and cars? I got there way too early and started drinking immediately. The video idea popped into my head as I was in the middle of unloading. Hence the 'mess' inside and outside the trailer.
24Chromium is offline
Old 06-06-2017, 11:05 PM
  #617
DTMiller
DTMiller's Avatar
To be clear I think it's fantastic and you clearly take great pleasure in the details.
DTMiller is offline
Old 06-08-2017, 01:45 AM
  #618
mooty
GT3 player par excellence
mooty's Avatar
Received 5,630 Likes on 2,314 Posts
take not of 24chromium's helmet blower. $$$ but oh is it sexy. so nice i got two from him.
mooty is offline
Old 06-08-2017, 02:43 AM
  #619
24Chromium
24Chromium's Avatar
Originally Posted by mooty
Take note of 24Chromium's helmet blower. $$$$$$, but oh, is it sexy. So nice i got two from him.
FIFY
I know I always say "you're not from this planet." But now I know it's completely true! YOU HAVE TWO HEADS!!
Old 06-29-2017, 01:31 PM
  #620
ngng
ngng's Avatar
If you ever bring your trailer by work I'd love to take another look, I sold my 40' 5th wheel and have "downsized". I remember poking my head in at a PCA event and thinking, this would work really well in my future traielr!
ngng is offline
Old 07-04-2017, 04:23 PM
  #621
ngng
ngng's Avatar
Originally Posted by Phokaioglaukos
Gentlemen, please be certain to have the protective cap on the cylinders when they are being transported, or any time they are not in use. Many cylinders contain pressures that are in excess of 2000 pounds per square inch. A broken valve is all it takes for the cylinder to become an unguided missile. I hope the images in this thread are intended to illustrate the use of the cylinders and that the regulator is removed when not in use and the protective cap installed. Even though your cylinder is firmly attached to the trailer, stuff happens. A valve knocked off a gas cylinder WILL cause much damage and possibly personal injury.
is that really an issue? the nitrogen cyls people are sticking in their trailers seem are "only" 2k psi. we regularly transport high pressure scuba cyls that are 3300 psi and scba cyls at 4500si without any caps. regardless, a cap doesn't take any extra time and does offer a piece of mind
ngng is offline
Old 09-05-2017, 10:06 PM
  #622
24Chromium
24Chromium's Avatar
All these years that I've owned my trailer, I've done zero in terms of maintenance, save replacing tires. I'm finally on my first true long-distance haul, from NorCal out to Road America in Wisconsin. A whopping 34 hour tow one-way. Prior to departure I installed new wheel bearings and brake shoes. As I type this, I'm on my way back home and happy to report I've had a trouble-free trip so far. My point is, don't be like me. Have your trailer serviced regularly.
Old 09-06-2017, 01:34 AM
  #623
montoya
montoya's Avatar
I did mine a couple of years ago and the report was that I could have waited, but like you it's better to have peace of mind. I would think if your trailer is stored indoors, then it's more a function of miles than time (within reason) as to when you need maintenance. Did you get any recommendations for a service interval?
Hope you enjoyed Road America, what a great venue! Only done it once but love the resort and community. I made a jog around the original course and took pictures of all the memorials- my favorite was this one, LOL!:
montoya is offline
Old 09-06-2017, 02:00 AM
  #624
Spyerx
Spyerx's Avatar
Received 1,781 Likes on 1,084 Posts
There is a trailer repair shop not far from me. It is all they do. It's less than $200 for them to pull the hubs inspect and repack the bearings inspect and adjust the brakes and fully inspect the trailer. I do it annually.
Spyerx is offline
Old 09-19-2017, 04:46 PM
  #625
24Chromium
24Chromium's Avatar
I've done a few updates this season. I've added two new D-rings on the floor at the rear of the car. I'm now using a couple of very short fixed length straps secured to the tie-down points on the rear of the car. Ratchet straps at the front cinch it down tight.
I also added insulation in the ceiling. My framing is 1-1/2" square steel tubing. I chose 1-1/2" thick EPS (expanded polystyrene) that has a skin on one side and a metalized mylar on the other. It comes in 4' x 8' sheets. I simply cut it to shape to fit the bays and secured it with 3M double-sided tape.
The results are very noticeable. An added benefit is that it's now a bit quieter inside as well. The next step is to decide if I want to skin the ceiling in some sort of material. I could just use sheet vinyl or a thin plastic, or even formica. I'd like to have it bright white like it was originally.
Old 09-19-2017, 06:06 PM
  #626
Klepper
Klepper's Avatar
...I also added insulation in the ceiling. My framing is 1-1/2" square steel tubing. I chose 1-1/2" thick EPS (expanded polystyrene) that has a skin on one side and a metalized mylar on the other. It comes in 4' x 8' sheets. I simply cut it to shape to fit the bays and secured it with 3M double-sided tape.
Do you think the insulation adds any significant weight to the trailer? I wouldn't think much, but wanted to get your opinion.
Klepper is offline
Old 09-19-2017, 08:19 PM
  #627
24Chromium
24Chromium's Avatar
For what I installed, probably less than the weight of a case of beer.
Old 09-21-2017, 12:29 AM
  #628
Spyerx
Spyerx's Avatar
The insulation was great
Next mod: bug light / zapper
Spyerx is offline
Old 09-22-2017, 03:16 AM
  #629
mooty
mooty's Avatar
ceiling: pls make it nicer. carbon fiber sheets comes to mind. make it happen
mooty is offline
Old 09-23-2017, 05:16 PM
  #630
24Chromium
24Chromium's Avatar
I was thinking of putting a mirror on the ceiling. The grid girls like it wild.
Quick Reply: My Trailer Diary
