New Trailer. Questions
Learning as I go.
- Trailer is great with 3500 pound BMW in it. Truck still wanders, but it wanders on its own so I need to look at the front end again.
- The side door keys broke almost immediately. Need to find a better latch.
- I will replace the floor after some use with thicker, better plywood and seal it with some good 2part epoxy.
- I had my son clean and wax it. Looks much better.
- Will get the electric trailer jack because that is ridiculous to do every time you disconnect. And the low hitch on the truck is still too high.
- Finally getting to understand the P3 from Tekonsha but its finicky. And the boost seems to put the brakes on a bit all the time.
- For track days I will maybe use it to sleep in instead of getting Hotels. Seems there is enough room except for the taking a shower thing. I'll have to think about that.
- I have studied and I think t he COmeUp Trailer winch is best bet. I will make an infloor mount for it out of steel (Someone sells aluminum - don't know about that)
- Also want to put deep cycle battery system in the floor as well.
