Help with trailer size
Old 03-11-2019 | 10:03 PM
gnathologist's Avatar
gnathologist
Originally Posted by PGas32
Now it’s time to go truck shopping!
Looking into 2019 Ram 3500 Dually!!!
My wife will have me by my throat but I’ll live through it lol
Seung
Old 03-12-2019 | 12:21 PM
Hoyt's Avatar
Hoyt
You'll love the Intech trailer.... I've got a 28' regular trailer from them and its the best trailer I've had so far. Oh, and if you didn't already know this, Intech will send you a website link to see the photos of various build stages.
Old 03-12-2019 | 05:03 PM
gnathologist
I just finalized the options. Here are the specifications of the trailer.
See below. I should be getting the drawings from Intech in about 3-4 weeks. I will keep you guys informed if interested.
Intech 44' Gooseneck
Product: 6000# Axle Trailers
Length: 44.00
Width: 8.50
Height: 8.00
Number of Axles: 3
Axle Type: 6000# Torsion Axles
Exterior Color: Med. Charcoal Grey
Interior Color: Silver Frost
Cabinet Color: Penske Yellow
Cove Color: Penske Yellow
Wheel Style: TBD
Model #: BGA8544TTA4
Chassis
- Full Perimeter Aluminum Frame
- All Tube Construction
- Dexter Torsion Axles
- Electric Brakes - All Axles
- Breakaway Battery Kit
- 7-Way Trailer Plug
- 2 5/16" Adjustable GN Coupler
- Safety Chains w/ Storage Loop
- Dual Leg Manual Landing Gear
- 16" O/C Floor Crossmembers
- 16" O/C Wall Studs
- 16" O/C Roof Studs
- Smooth Aluminum Wheel Boxes
- Spread Axle Design w/ Individual Fenderettes
- ST235/80R16 Nitro Filled Tires w/ Steel Wheels
Interior
- One Piece Aluminum Subfloor Vapor Barrier
- 3/4" Plywood Subfloor
- (3) 12V LED Dome Lights w/ Switch
- (1) 12V Power Roof Vent
- 7' Standard Interior Height
- (4) 5000# Recessed D-Rings
- 4' Beavertail
Exterior
- .030 Aluminum Skin
- Screwless/Rivetless Aluminum Exterior
- One Piece Aluminum Roof
- Arched & Trussed Walk-On Service Roof
- 4" Upper and 6" Lower Rub Rail
- Clear Anodized Exterior Trim Package
- LED Premium Clearance Lights
- LED Slimline Tail Lights
- ATP Enclosed Riser w/ (2) Storage Doors
- 36" 405 Series Entrance Door
- FMVSS Premium Entrance Door Latch
- Color Matched Front Verticals
- Rear Ramp Door w/ Gapless Continuous Hinge
- Aluminum Bar Locks - Rear Ramp Door
- Rear Skid Plates
Selected Options:1 each
44' iCon Package
Exterior Upgrades
- Upgrade to 48" 405 Series Door
- Aluminum Slide Out Step
- Upgrade to Aluminum Wheels
- Upgrade to .040 Exterior Aluminum Skin
- Upgrade to Cast Corners w/ Stainless Steel Verticals & Radius
- Stainless Steel Rear Header & Posts
- Upgrade to Stainless Steel Paddle Latches
- 40" x 36" 405 Series Generator Door
- Awning Rail
Electrical Upgrades
- 50 Amp Electrical Service
- 50 Amp Gen Prep w/ Transfer Switch
- Requires 240V Panel Upgrade to Use 240V
- Motorbase Plug & 25' Shore Cord
- 12V Battery & Box Wired
- Battery Shelf in Riser Compartment
- 12V Fuse Panel
- 60 Amp Converter for 12V
- (3) 20 Amp Interior Recepts
- (1) 20 Amp Exterior Recepts
- (5) 12V 18" LED Interior Lights - Replaces Domes
- 3 Way Light Switch for Interior LED Lights
- (2) 12V Surface Mount LED Flood Lights
- 12V Cutoff Switch
- Upgrade to Panel Lite Exterior Lights
- Upgrade to Dual Brake Lights
Interior Upgrades
- Screwless Aluminum Walls & Ceiling
- Add Roof Vent w/ Wire for Future AC
- Extruded Aluminum Floor
- Gray Carpet in Riser Area
- Extruded Aluminum Ramp
- One Piece Aluminum Transition Flap
- 8' Premium Aluminum Upper Cabinet
- 8' Premium Aluminum L Shaped Lower Cabinet
- LED Light Under Upper Cabinet
- Gen Compartment in L Cabinet
- 8' Interior Height Maximum w/ Package
2 Each
Upgrade from Surface Mount LED Flood Light to Whelen 900 Series Super LED - Each
- Dimmer Switch Included
1 each
Upgrade to Recessed Stainless Steel Latches into Ramp Door From Paddle Latches- Pair
- Stainless Steel Rear Ramp Door Not Available
- If Optioned with Heavy Duty Rear Ramp Door, Door Will Not Have Full Rating
1 each
Upgrade to 95.5" Rear Ramp Door Opening
- Bar Locks Used - Paddle Latches Not Available
- Upgrade to Ramp Door Mounted Tail Lights Included
44 feet
12" Additional Height / Ft
1 each
Rear Caster Wheels - Pair
1 each
Upgrade to Single Post Hydraulic Jack - Battery Not Included
2 each
Spare ST235/85R16 on Steel Wheel
2 each
Upgrade to Aluminum 16" Wheel From 16" Steel Wheel - Per Wheel
Spare
2 each
Spare Tire Wall Mount - Specify Location (Interior or Exterior)
1 each
Upgrade to 60" 405 Series Double Door
1 each
Add Full Access Escape Door - 6' Tall - Triple and Super Spread Tandem Axle
- Uses 2" Wall Framing Structure Around Door
- Quick-Remove Interior Wheelbox
- (2) Gas Shocks
- Integrated Wheel Well Step Included
- SS Side Trim Requires Extra Charge Option
- Includes (2) FMVSS Locks
1 each
Add Rear Glass Sliding/Fold Away Double Doors
1 each
Add 5' Aluminum Ramp Extension - 84" Wide w/ 3" Bumpers
1 each
7.0KW Onan Generator Package (120V/240V) - Gasoline
- In Frame Fuel Tank
- Interior Insulated Generator Compartment
- 40" x 36" 405 Series Vented Gen Door
- Automatic Transfer Switch
- 12V Marine Grade Battery in Vented Box
- Remote Start, Fuel Gauge & Hour Meter
1 each
Add 12V Power Outlet w/ (2) USB Charging Ports
5 each
Add 12V 18" LED Interior Light
- Maximum of (6) Per Switch
(9) Total; (2) Rows of 4
(1) Underneath Upper Cabinet
10 each
Add Panelite LED Clearance Light (Ea)
1 each
Add Panelite Backup Lights - Pair
1 each
Side Mount LED Turn Signal/Clearance and Turn Combo (Pair)
1 each
Add 12V LED Docking Back Up Flood Lights (Pair)
- Floods Area Behind Trailer when in Reverse
4 each
Add 12V Loading /Tie Down LED 11" Light - Per Light
- Specify Location and Use
Interior Tie Down Lights
44 feet
Add Carpet on Interior Walls - 34" High / Ft
44 feet
Insulated Walls & Ceiling - R4 Rated (Up to 18" Additional Height) / Ft
- Bubble Foil Insulated Ceiling
- EPS Insulated Walls
2 each
Add 4' Premium Upper Aluminum Cabinet w/ Clear Anodized Trim
- Standard: 16.5" x 14"
(1) For Furnace and Microwave
(1) Located at Rear; Curbside Wall
1 each
Add Aluminum Dresser Closet to Lower Cabinet
- Standard: 24" x 24" x Up to 84"
- Specify Full Height or Above Counter
- Includes Shelf and Clothes Hanger
For refrigerator
1 each
Wheel Well Cabinet Triple Axle - Width of Wheel Well - Up to 7' Interior Height
- Clear Anodized Trim
- (2) Adjustable Shelves in Each Compartment
1 each
Black Anodized Interior Package - (Includes Upgrade to Items as Optioned on Order)
- Interior Door Trims
- (1) L-Base Lower Cabinet
- (1) Straight Upper Cabinet
- Additional Cabinet Trim Upgraded Separately
- J-Rail on Cove
- J-Rail on Bottom of Sidewall Metal
- J-Rail on Spring Box
- J-Rail for Carpeted Areas
20 feet
Black Anodize Cabinet Trim / Linear Ft of Upper or Lower Cabinet
For Wheel Well Cabinet and Rear Upper Cabinet
4 feet
Aluminum Countertop - 24" Flip Up / Ft
- Stores Folded Down Against Wall
Located on Curbside Wall @ Rear, Underneath Upper Cabinets
44 feet
Add Airline Track - Surface Mounted / Ft
@ Carpet Line; Estimated Qty/Length
40 feet
Add Airline Track - Recessed / Ft
(2) Rows of 20'
10 each
Airline Track Double Stud Tie Down Ring
Estimated Qty
2 each
Adjustable Tire Rack - 8' Fold Up Wall Mounted
- Includes Carpet on Wall Behind Rack
- Support Beam Adjustable
- Fits Tire Diameters from 14" to 32"
Located in Riser Area
1 each
18" Wide Tie Down Strap Hangers - Pair
- Protective Wall Carpeting Installed Between Hangers
1 each
Black Anodized Exterior Package - (Includes Upgrade to Items as Optioned on Order) - GN
- ATP for GN Riser Area
- Stoneguard & J-Rail
- Entrance Door Step
- Exterio Door Trims (455 Series Door Cannot Be Black Anodized. Requires Separate Powdercoat Option)
- Exterior Fenders
- Upper and Lower Rub Rail
- T-Trim & Angle Around Rear Ramp Door
- Drip Rail
- Awning Rail
- Rear Ramp Door Grab Handles
1 each
Upgrade to Lowered Skirt w/ Reverse Beavertail Design - Triple Axle
1 each
Color Matched Rear Spoiler - Specify Original or New Style
- Includes (2) Integrated LED Loading Lights
- Original Style - Color Matched to Rear Header
- New Style - Requires SS Rear Header & Posts
1 each
Wiring for Loading Lights on Rear Spoiler to Activate as Reverse Lights
1 each
Add Awning - 21' Dometic w/ Weathershield - 12V Power Awning
- Std: Pewter Vinyl w/ White Hardware on White Trailers
- Std: Pewter Vinyl w/ Black Hardware on All Other Colors
- Includes Awning Cradle
1 each
(2) 20# LP Tanks - w/ Regulator & Quick Disconnect
2 each
Add 15,000 BTU A/C - Low Profile (11.25")
- Includes Digital Wall Mount Thermostat
- Heat Strip Not Available
- Standard: White Exterior Cover on White Trailers
- Standard: Black Exterior Cover for All Other Colors
Black Covers
1 each
Add 35,000 BTU LP Furnace
- Cabinet Sold Separately
- (2) 20# LP Tanks Included
- Safety Package Required - Optioned Separately
1 each
Upgrade Upper Cabinet Depth to House Furnace
- Uses Bottom Hinged Cabinet Access Panel
44 feet
Upgrade to Ducted AC / Ft
- Increases Size of Trussed Roof to Fit Ducting
- Larger Trusses Must Run Full Length of Rooms in Trailer
- Not Available with All A/C Models
- Not Used for Bard A/C's
1 each
In Floor Winch Box w/ Pulley - Angled Mount
- Designed for SuperWinch S5500-SR or Warn ProVantage 4500-S
1 each
5500# Winch w/ Wireless Remote Control & Synthetic Rope
1 each
Add Air Compressor w/ 3 Hardlined Outlets
- Outlet is Switched with a Dedicated Switch
- Airline Rated at 200 PSI Max
1 each
Air Hose Reel - 50' Retractable w/ 3/8" Hose
- Requires Air Hose Outlet - Optioned Separately
- Includes Fairlead Roller if Mounted in Cabinet
1 each
TV Prep Package
- Roof Mounted Antenna
- Exterior Coax Cable Inlet
- 120V Interior Recept
- Wall Backer for Future Mount Installation
- 12V Antenna/Cable Switch Controller
1 each
Add AM/FM/CD Sirius Ready Bluetooth Stereo w/ Four Interior Speakers
1 each
Upgrade (4) Interior Speakers to Premium Fusion Soundbar
1 each
Add Microwave - 1.0 Cubic Ft. - Integrated into Cabinet w/ Faceplate
- Cabinetry Optioned Separately
- Includes Dedicated Outlet
1 each
Add Refrigerator - 2.7 Cubic Ft - 3 Way (12V, 120V, LP)
- Does Not Include Cabinet
- LP Tank Kit Sold Separately
1 each
Safety Package
- 5-BC Fire Extinguisher w/ Wall Bracket
- Smoke & Carbon Monoxide Combo Detector
- LP Gas Detector
Old 03-12-2019 | 09:14 PM
ExMB's Avatar
ExMB
Received 1,386 Likes on 843 Posts
Seung
Better than
Old 03-13-2019 | 10:29 PM
Mussl Kar's Avatar
Mussl Kar
Maybe I missed it but manual landing gear sucks. Last thing I want to do at the end of a good day. Also, in floor winch had better line up with your cars tow eye location. And they never do. If the winch is not in line with the tow hook the cable will bunch to one side and jam. Winch in a pit with a pulley mast looks cool, but really a useless POS. For starters the pulley must be at least the diameter of the winch drum. If it is smaller then that pulley will put a nasty bend in your cable and soon wires will start breaking.
But all else looks well appointed. Other than the solar power.
Old 03-13-2019 | 11:43 PM
gnathologist
I’m not sure about the manual landing gear. It’s been upgraded to a single post hydraulic jack but I can’t imagine not having a manual landing gear on each side of the trailer for stability. I guess I can ask my dealer.
Maybe I can ask about installing a winch off center to line up better for GT3. Not sure if everyone is having the same problem. Maybe synthetic rope won’t bunch up as easily?
Please let me know if there are any other helpful pointers. Anything you would have done differently on your trailer would be helpful.
Thanks.
Seung
Old 03-14-2019 | 09:14 AM
Mussl Kar's Avatar
Mussl Kar
Thanks.
Seung
If will bunch up if pulling off center and when I had the winch in the pit I also had to use a ****** block tied to one of the D rings to partially solve the problem. As the car got closer it had to be unhooked and final pull bunched up just a little. I now have my winch mounted to a billet aluminum fat T bar that is anchored to the front wall of my GN trailer. Winch slides to the right for GT3, or slide it to the left for the McLaren.
My manual landing was just a PITA to me and took some effort. A friend wanted to help me set up at an event and even though he was strong enough to turn the crank, he did not weigh enough once the crank went to top center, could not get it down. Other drawback was uneven ground and I needed to keep a few pieces of plywood on hand to make sure both feet were supported the same height as one crank lowers both legs and if not even it would twist the trailer. When one side crapped out I replaced both with BullDog electric landing gear. Electric has 2 switches. Lower one leg until it bears a little weight, repeat for other leg. The press both switches to evenly raise the trailer.
Old 03-14-2019 | 11:30 AM
gnathologist
This is great. Thank you for the information.
I’ll definitely ask to see if sliding winch is an option to accommodate both GT3 and Exige. I didn’t know such existed for electric landing gears. I’ll add that to the list.
Appreciate your insight!
Quick Reply: Help with trailer size
