FS: 2007.5 Ram 2500 6.7l diesel
2007.5 Dodge Ram Thunder Road Edition. Truck is in better shape than most of others much newer. It was meticulously maintained and upgraded. Equipped with a towing torque monster 6.7L Diesel and a 6 speed Auto Transmission. Add to that a Crew Cab with original but brand new looking leather seating front and back, fantastic AC, and a factory towing package with folding side mirrors, Aluminum factory wheels and an upgraded Class V Reese tow hitch. The bed has a locking fiberglass painted bed cover. The bed is coated and setup for a fifth wheel with a secondary 7-Pin connector. In the cab is a brake controller and factory electronic engine braking control. Now the upgrades. Suspension in rear is from the Ram 3500 with airbags for ride height control under load. The engine has lost some of its inefficient controls and augmented with better breathing and exhaust giving it tremendous power with economy over 22 MPG(34 gallon fuel tank). In the past 30,000 miles the entire front suspension was replaced with all new control arms, new Bilstein shocks were installed, every bushing, all ball joints and wheel bearings, brake pads and rotors were installed, new tie rods and sway bar bushings (was not really worn out but just wanted truck perfect and I'm in auto business). Recently I replaced both batteries with Interstate units, and augmented the transmission with a finned aluminum deep sump (5 extra quarts) to keep transmission cool. Inside you will be riding with a new sound system incorporating Satellite Radio, HD Radio, and CD capability. You will not find a better truck out there in both mechanical and interior/exterior finish. While the odometer shows 229,xxx the Cummins Diesel has many hundreds of thousand of miles left and you will find the truck has been overly cared for and maintained needing nothing but a new owner that can use its capabilities. It is perfect for any business, or personal where you might be towing a very large boat or camper. Must see. Title in hand. $15,000 In Tampa..
