Charge timer / profile setup question
Old Jan 15, 2024 | 05:22 AM
rennlistfan's Avatar
rennlistfan
Default Charge timer / profile setup question
I'm on slow L1 home charging and need to maximize SOC but trying to avoid the peak electricity rate between 4pm to 9pm daily. I find the charge timer / profile not very reliable. If I set SOC minimum in profile to 25%, charging will not resume after the 9pm peak. If I set SOC minimum to 100%, it will charge right through the 4pm to 9pm peak. Any advice on how to setup the timer so I can leave it plugged in 24/7 but don't have to "babysit" the charging? Thanks.
Old Jan 15, 2024 | 08:12 AM
d00d's Avatar
d00d
Here's a video and my summary;
https://rennlist.com/forums/taycan/1...l#post18806242
Old Jan 15, 2024 | 12:45 PM
rennlistfan
Originally Posted by d00d
Thanks! The PCM and phone app are still buggy as hell. You really need to use BOTH profile and timer (with hypothetical "departure time" to fool the car with desired SOC) for optimized charging at preferred times when the profile alone should be doing this if it's coded right.
