How to "downshift" for sharp curves?
How do you get more control when you want to take a curve fast? From time to time the car feels like it's in a "gear too tall" for the curve and there's not much you can do since it's EV. Are you meant to hit the regen button for "engine braking" or are you meant to step on it and let the low CoG work its magic?
P.S. I wish there are paddle shifts on the steering wheel for controlling regen and regen levels like on the Mercedes EQ EVs.
AlexCeres (09-12-2023)
You maybe need to manage the longitudinal weight transfer a little differently by perhaps braking more on corner entry and then applying power earlier to shift the weight rearwards? One of the nice things about the RWD Taycan is that it rotates beautifully around the drivers seat, so feels verify satisfying to drive fast through corners (at least with PTV+ and RWS).
My RWD has Sport+. Is this part of the Sports Chrono package?
wait what?
its an EV
Floor it.
why are you down shifting? Brake into apex, rotate, FLOOR IT.
its an EV
Floor it.
The following 5 users liked this post by Spyerx:
24Neptune (01-23-2024),
AlexCeres (09-12-2023),
kort677 (09-13-2023),
pjazz (09-14-2023),
thebishman (09-13-2023)
GT3 player par excellence
wot
enter
lift
wot
it’s not geared tall u need to go faster
enter
lift
wot
The following 3 users liked this post by mooty:
Have you considered hitting up PEC and spending 90 minutes with a car like yours and an instructor on a circuit ? They can help you push it much harder than would be safe on the street and get a better feel for the limits. Plus they’re all awesome pros and can answer any questions about manipulating the car at speed.
honestly has me wanting a much lower weight small agile sportscar EV, I think will be stupid fun in the twisties.
The following 3 users liked this post by Spyerx:
I've only driven my GTS and a Turbo S at PECLA. All I have to say is that there is no need "downshifting" because both the cars had huge torque at the press of the gas pedal. Having driven so many Porsches over the years I've NEVER experienced the kind of torque that these Taycan produce. From stop to full speed it pulls like a rocket ship compared to all the other Porsche cars that I've owned, the torque is pretty addicting and spoils me when I get back into a non-EV car.
When approaching a corner at speed in Normal, I twist the dial to Sport or occasionally Sport+ to get regen braking and to stiffen the suspension one or two clicks. (I have RAS and PDCC-Sport.) At one intersection where I am often racing to catch a left-turn arrow onto a busy suburban 6-lane street, I'm tucking into the near lane. The corner is greater than 90 deg and somewhat off-camber. Probably because I take the same corner in my 911 TTS at speed, I like the feel of regen braking as I set up for the corner and brake as late as possible. This corner is less than a half-mile from a police station so I do stop short of four-wheel drifts to entertain the other drivers, though. The area where I live has a lot of hills and I sometimes use Sport going downhill to keep my speed somewhere close to the speed limit. I also feel I'm not riding the brakes, but maybe that is what is actually going on. I should figure that out.
I took delivery of our Taycan GTS at the L.A. PEC and drove a Turbo S on the track because they didn't have a GTS in the fleet at the time. It was a great experience. As others noted, I thought the car is surprising capable on the track. It did feel heavier than my 911 which is 1,400 pounds less, but it was stable and fast. In fact, we got the go-around wave by a few times. I could almost hear tire rubber exiting the tires on some of the tightest turns on the track as you could pick up a bit of drift. All OK, though. BTW as much as I've enjoyed the thrust from a stop, when punching the accelerator at about 45 or 50 mph, I am amazed by the response.
a couple months ago I took delivery of a taycan with a buddy at PEC, we split the driving time and got some good lunch after, driven the track there a few times there prior (this is the one in LA). lets just say, the taycan turbo s is surprisingly astute, you do feel the weight, but its not hard to get it into a pretty progressive slide in corners and like I said, brake, FLOOR IT, that 4wd just pulls out of the corner. tires get greasy after a couple hard laps though, weight....
Expensive for sure, but uber fun.
Der-Schwabe (09-14-2023)
