Parking height and driver seat
My '17 Cayenne was totaled (by someone else) so I'm shopping.
I rented a 4 Turismo via Turo. I notice it has a way to set a higher setting when parked at a specific location.
Like my GTS it had seat and steering wheel memory and would move those when exiting.
Is there a way to set the lift height for ALL park/exiting? Likewise, can the seat's rearward position be set for the parking exits?
I ask this because I'm a big guy with back issues. The Cayenne was a breeze for entry/exit. The Turismo.... less so.
you can set the ride height in normal mode, and that is retained unless you go into gravel mode. When the car starts, it defaults back to normal mode and whatever ride height it was selected. So if you set normal to high, then when youre about to park flip it into normal and it will stay at that height while parking and starting. then flip it into sports or sports plus when you drive.
