2023 4SCT on new BC Forged KL11's
Not the best pictures but I’m really happy with the package. I subtracted 12mm from the offset and have just the poke I wanted. With RWS I didn’t want them right on the fenders.
Here’s the specs.
Front
21x9.5" +48 - PZ4 265/35x21” NF0
Rear
21x11.5” +54 - PZ4 305/30x21” NF0
Color: Gloss Brushed Grey (Translucent)
https://bcforged-na.com/
For reference here are the weights. These are wheels and tires.
Front
Factory 20” = 59.6 lbs
BCForged 21” = 53 lbs (25 lb wheel, 28 lb tire)
Savings = 6.6 lbs / corner, 13.2 lb / axle
Rear
Factory 20” = 66.4 lbs
BCForged 21” = 59.8 (27.8 lb wheel, 32 lb tire)
Yes, both have the exact same weight difference, that’s quite a coincidence. 26.4 lbs is a lot of savings considering these are bigger wheels and tires. I was shocked, at best I was expecting them to be maybe 2 lbs per corner considering the upsize. The factory Porsche 20" Turbo Design wheels are real porkers coming in at Front = 31.6 lbs and Rear = 35.4 lbs EACH.
Also note that the color balance under an overcast sky with the iPhone makes these look a lot more silver than they really are. In person they are at least one shade darker.
Here’s the specs.
Front
Rear
Front
Rear
The following 2 users liked this post by mjw930:
cyclrder (08-04-2023),
thebishman (08-03-2023)
Great looking set up with the Volcano Gray exterior. Are you thinking of adding Porsche crest center caps? Looks good as it but a potential consideration. Enjoy and have fun out there.
I have their smooth centers that I'm going to try and find a quality vinyl crest to apply. They do offer the option of having the center bored to accept OEM Porsche center caps, I did not opt for that.
CTB (08-03-2023)
