Used Taycan considerations - Need tips
1) Is there significant difference in battery performance, or infotainment or any critical components between MY2020, MY2021 and MY2022?
2) If buying from a private seller with a 2-3years leftover factory warranty, are there warranty extension options? (Does Fidelity offer extended warranty on EVs?)
3) If Carfax is clean and car looks good cosmetically, is there anything that needs to be looked at during a PPI? Better yet, who even does PPI for these? (local Dealer told me they dont do PPI anymore for any cars)
4) Would having an Indy mechanic connect something like an ECU computer show anything meaningful in terms of abuse or errors?
5) Anything to cautious about apart from the obvious, like know issues with certain model years?
https://factoryprotect.ratessys.com/
Michael Bernardo | Steingold Volvo Cars | FactoryProtect.com
Discounted Extended Vehicle Protection Plans | Rennlist Forum Sponsor
michael.bernardo@steingoldvolvocars.com | 401-723-4700 x126
Purchase Extended Warranty Plans Online Now: https://factoryprotect.ratessys.com/
Learn more about Vehicle Protection Plans: https://steingoldvolvocars.factoryprotect.com/
PS: Be sure to use promocode: RENNLIST for $200.00 Member Discount!
https://rennlist.com/forums/market/1345421
NF
ADDITIONAL HYBRID/PLUG-IN ELECTRIC/COMPRESSED NATURAL GAS/HYDROGEN COMPONENTS: Motor/generator belt tensioner;
drive motor dampener; voltage inverter reservoir; three-phase high voltage cables; hydraulic or electric regenerative braking system; hybrid/
EV/hydrogen battery (nickel-metal hydrate or lithium-ion drive propulsion battery) including the case and mounting hardware, junction
block, main battery cable, and frame wire; onboard battery charging system including charge controller, plug in outlets, plug in cable, and
trickle charger cable; electric AC compressor and motor; electric steering rack, gear, and motor; electro/hydraulic power steering pump and
reservoir; hydrogen fuel cell stack; battery cooling pump; seals and gaskets
Your place for distinguished automobiles, proud provider of GWC/Easy Care & Freedom Warranty extended warranties. Visit us at Highline-Autos.com
Official RECARO Automotive Retailer: www.highline-autos.com/product-category/recaro/
Highline Autos Magazine - Volume XXII, Number 05 https://isu.pub/dXwCIV1
Although I did add the 48 lbs air suspension, because lowest setting increases efficiency.
I'm coming from an M5, don't miss the power, which seemed to be torque limited.
The Taycan's faster than a 930, without the snap over steer.
My charging uses the general profile at 35% so I can still precondition the interior after a short trip, otherwise less than 25% doesn't allow.
I use a timer to get to 100% 10 minutes before I leave for the commute.
- How pitted is the windshield? Does it need replacement?
- Any chips in the glass roof?
- Any wear on the plastics (nose, side rails, rear diffuser?)
Enjoy the experience!
