Just got my 987.2 Spyder what should I do about this
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
As far as my Spyder attitude goes, even with all of the snafu's I am still excited as hell to have this car! I will also now be asking for $$$ for my time and diminished value on the scratch now (thanks!). I stole the car for $46k so I am already ahead, throw in the $9000 top (I know I would never pay that, but somebody DID!) and I am feeling pretty damn good right now!
Wow! Rare indeed. I know of another 987 Spyder owner who loved the red interior, but passed because he just thought it was too much red and needed black contrasting interior appointments to break things up a bit. If I'm not mistaken, he told me 2011 cars came with all red interiors, but in 2012 they went with red seats, but black carpeting. Good for you to land a car with this contrasting interior you preferred!
The carbon top looks cool, definitely a unique piece. Does it weight alot?
No not yet....I may just do it myself as I have extensive paint/touch up experience. I will probably this tape it off and fill with 80/20 and wet sand it out. I can live with that I believe. Sucks, because it was the only spot other than minor chips.
Sorry to revive an extremely old thread but going through the 987.2 Spyder threads, I came across this and had to ask some questions. I've never seen anything like this before from Porsche so is this a factory option and if so, how much and what is the option code? I assume the front attaches using the normal attachment but how does the rear end of it attach since there's only the two pegs and the two anchor points on the rear decklid which from the pictures, this hardtop doesn't seem to be using in anyway?
Here’s the part number in case you’re looking for one:
8465-K56H-FUGLY-NJF8
DaveGee
DaveGee
The following 2 users liked this post by DaveGee:
halfmonkey (08-04-2022),
Only1Buck (07-31-2022)
I deal with scratches like this a lot. Someone with a lot of experience can make that look much much better but it takes skill to do it.
The way I would address it is too carefully fill in the low spot with black touchup paint using a paint pen that is used for signing artwork. They have an orifice you put a few drops of paint in and they have a tiny tip. Here is an example
Let that dry, then use something like Lanka blob eliminator to level it out. http://www.langka.com/index.php/feat...lob-eliminator
You can either fill it and level it with the blob eliminator and call it good, or only add enough black cover it and then use professional two part clear over it and then color sand or level it with a paint plane such as the Festool LZK-HM.
Again, it takes skill and you can really screw things up if you are not careful but you may find someone local who does this stuff for high end dealers as a living. Call around and ask them for referrals for guys that touchup paint. It may not be perfect, but should be pretty good if they are skilled.
The Lanka solution is pretty easy and you wont damage anything with it so worth a shot. Once you get into sanding or shaving the high spots, that is where things can go wrong.
David
David
