Cayman R vs. Boxster Spyder
Thanks.
What is you best guess on the difference? Is the small amount of additional stiffening (chassis and suspension claims) just that little bit to much?
And, based on your experience, do you think swapping to R-compound tires would benefit the R more than the Spyder?
Thanks, again.
Thanks, again.
1. Something I've seen before with a select few open Porsches (997-1 Turbo Cab comes to mind): the open car's less-stiff structure may be allowing the wheels to follow the road better, and is thus either more confidence inspiring or actually more grippy —* or both. Local autocrosser and track instructor (and decades dominant) Terry Zuccone talks about this when talking about his super-high-mile 911 Targa, and I think he speaks from a credible platform. I am not, however, suggesting that open cars make better platforms. What I am saying is that, in certain situations, and with certain development limitations, there may be cases where the extra "give" or "compliance" in the chassis may work out to a faster car, or at least one a driver is able to use more of.
2. I understand the Cayman R got the go ahead after the Boxster Spyder was so well received. Like the Cayman S was, it is an adaptation of an existing Boxster, and a review of its suspension components reveals that few are different as one might expect given that it's a closed car. This may work with the point above.
I'd have been curious to see the difference on a full track, but it just wasn't to be. However, Johannes' test is but one of four components in the new issue, and the others are probably more revealing, if not in numbers than in impressions. There are advantages to the Cayman R's structure, and these showed up on our road-test loop.
Great thing with Johannes is that I can always be confident in his ability to get the most out of the cars and then interpret the result intelligently against his breadth of experience.
The fact he is not on any manufacturer's payroll doesn't hurt, either...
pete
I am a long time 944/951/968 owner and have a very nice examples of a modified 951 and a 100% stock 968 cab. I've recently been fighting the urge to swap out both and move into a Boxster Spyder after spending some time with one at the Porsche Driving Experience and thought I had gotten it out of my system. Your article didn't help! lol
Seriously, thanks for a great article!
Steve, my best guess is twofold:
pete
pete
pete
pete
Your first point matches my experience, too.
I'm a subscriber, so await that issue's arrival.
I've yet to drive an R, but the Spyder's suspension is magical. My R should be here by Thursday. I plan on driving it on R-compound tires. I guess I'll find out..
I drive a Spyder so I am partial to it.
However, just saw another test (street test) between the Spyder and Cayman R where they concluded the Cayman R was clearly the better & faster car.
http://www.gtpurelyporsche.com/thismonth.asp
There are so many variables that can factor into these tests, unless there is a wide margin between cars over a larger sample of tests (ie if every magazine that tests the Spyder vs the CR comes up with the same overall wide margin), there is no way of knowing with any certainty. Car set-up and alignment, previous use/abuse, did they use the same drivers, did the weather/temp/humidity/sunlight change, which car went first, had the drivers just eaten lucnh/breakfast or talked with their wife/husband between runs, etc will all change the results to some extent. There is also editorial bias that can creep into it, no matter how objective people can try to be. Its the same thing as doing dyno runs on different days, you really have a much harder time getting results that you can compare, especially if they are only incremental differences in performance.
It looks to me that you really can't lose between these two choices.
Pete, the Boxster Spyder/Cayman R story looks great, but I'll have to wait for the print issue to arrive to read about the 928 GTS story.
I've got a '94 GTS with 166,000 miles on the clock (and the Savannah PCA Parade Concours win, plus third place in autocross). This is a great driving car, but my '92 Mercedes 500E may be the favorite. 209,000 miles and still running strong.
Keep up the great stories and photos!
Interesting that 944/968/928 peeps are posting here...kinda feeds my pet theory about Porsche people, that there are three types: the ones who are interested in all of 'em, the ones who only like "the" Porsches (i.e. rear-engined ones), and the ones who like the models that aren't rear-engined.
Having had one 914, one 911 (after having searched for a good 968), and one Boxster and having loved them all, I am not sure where I fit in, but the fact I kept the 914 and let the others go probably says something about me...
While the Cayman R may have a stiffer structure and be slightly lighter, The spyder's center of gravity is lower which improves handling I have just glanced at the article as my Excellence just arrived today.
The R was a stripper - no AC, and sport buckets.
I received mine yesterday, and only had a chance to give it a glace as well - but it looks to be another great issue, Pete!
Anyway I loved that story on the two special mid engine cars.
Ooh, 500E... I strongly considered buying a one-owner Midnight Blue/Blue 500E in SF a few year ago. Miles were too high (150,000~), but it was MINT. Still kick myself for passing on that one from time to time.
But if I had another more practical car (like a 500E) and am looking for a new/recent Porsche, the Spyder and Cayman R are great choices. Between the two, it boils down to the climate I live in and how much track time I plan to do. The more dedicated track car I like, the more I'd lean towards the R. I've driven both - the R I drove at an autox track. I got sold on the Cayman platform and recently bought one.
