Spyder Sport Bucket Seat Question
I was reading in the Tequipment Brochure that the Sport Bucket Seats can not be used with Child Restraint Systems. Does this mean the side airbag can not be switched off?
My son is 6 and uses a booster seat which would fit perfectly but I want to be certain the Sport Bucket seats are safe.
Anyone know the answer to this?
Are you sure your booster seat fits? I only ask because the sport buckets are extremely narrow. My sons booster was too wide. Luckily he's 10 now and no longer has to have one. The sensor does shut off his airbag though.
Thanks for the info on the sensor, this is helpful.
We picked up a Britax Starriser which has a very narrow base on it. It fits easily in the back of my 928 and its one of the few that does fit back there. I'm going to measure to be certain and I'll post back.
I'm also looking at the Spyder, but want to have my 4yr old sit from time to time in a booster. Is there a booster that fits the buckets? Porsche seems to say that sport buckets are not to be used with any form of child seat (perhaps the integral air bags?). My dealer seems to think you can. Nevertheless, did you find one that worked? Thanks
The Britax Stariser booster seat fits into the sport bucket seats perfectly however the airbag can not be shut off manually. What I'm not certain about is if the airbags will be shut off automatically since the seat should sense a low weight.
I'm debating what to do myself and I'm going to be in the market very soon.
My 11 year old son is skinny enough to cause the passenger airbag to deactivate (75 lbs. or so). The only problem he has with the sport buckets is that his head is at the same height as the belt passage in the backrest. We've made a improvised head pad to tie off there when he wants to go for a ride.
Other than that, the buckets are so good, I'd have to have a pretty darn good reason NOT to add them to any future P-car I might buy from here on out.
Can you take a picture of the head pad you're referring to? My son will be in a booster but I think we will also need to move the belt down when he's in the car.
Thanks!
It's as simple as a long black boot sock with pillow stuffing held in place by a couple of knots. We put the ends through the belt passages and tie them off behind the center mesh screen. I can take a pic if you'd still like one.
If it helps i measured mine and the flat part of the bottom cushion (no bolster measured) toward the seat back is approx 12 1/4", the lower mid of the back inside the bolsters is a little more than 11"
I failed to mention in my earlier post that I actually placed the base of the Britax Starriser into the sport buckets on one of the local Porsche dealers Spyders and it fit snugly but it wasn't touching the side bolsters.
Quote from Porsche AG..."The sport bucket seats are linked to Motorsport. So it is not possible to use booster seats for the sport bucket seats (neither Porsche booster seats nor booster seats from other suppliers. "
Inability to turn off the integrated thorax air-bags? No idea. Sorry if this isn't what you (or I) want to hear.
Cheers
Cheers
FWIW, I finally found a booster seat that fits into the carbon bucket PERFECTLY. It's cheap ($40), and supposedly works even better than the bulky and more expensive options out there. Bubble Bum. It's not pretty, but hey it fits.
![](http://www.thenational.ae/deployedfiles/Assets/Richmedia/Image/SaxoPress/AD20110702810660-The%20Bubblebum%20b.jpg)
Maybe Heritage can re-do it in Red Alcantara for you. : )
But I never thought about this problem. I just assumed I could get a booster in the front bucket when my daughter was old enough. Hmm....this isn't good news at all.
