Spyder/Cayman R Discussions about the 987 Spyder/Cayman R (2011-2012)
How to interpret a DME report
Old 01-26-2024 | 09:00 PM
DaveGee's Avatar
DaveGee
Default How to interpret a DME report
I asked my local Indy to run a DME report for my Spyder. He gave me the report below. Is this complete, or is there data missing? And what does the report tell me?
DaveGee
Old 01-26-2024 | 10:00 PM
fatmike's Avatar
fatmike
I would expect to see different data.
Over/revs per range 1-6.
ia there anything else?
Old 01-26-2024 | 10:26 PM
DaveGee's Avatar
DaveGee
No, just the one page. I think others are missing.
DaveGee
Old 01-27-2024 | 08:45 AM
Bxstr's Avatar
Bxstr
13214/446=29mph average speed which is perfect and what I'd expect. Wondering where ranges 2-6 are, since it only seems to show range 1. My guess is there's something weird with the computer, but that is a minty report, you'd typically see range 1 and 2 on there. No concerns at all with only that small amount of range 1s.
Old 01-27-2024 | 09:01 AM
husker boxster's Avatar
husker boxster
A DME should have ranges 1-6 on the report. It'll show the # of occurrences that happened in that range and how many hrs ago since the last occurrence. So if you have 600 hrs total on the car and 5 occurrences in Range 2 and the last of those 5 happened 400 hrs ago, that's a good report card. Ranges 1 & 2 are generally not serious - they basically count the # of hits on the rev limiter. You don't want that # to be big, but your engine isn't technically being hurt by those. The issues start in Range 3 and get more serious with each higher Range and how recent they occurred. Now we're starting to talk about potential money shifts. You want low occurrence #s and many hrs ago. These will be in 3 & 4. You get occurrences in 5 & 6 and generally you have a sick engine or it's got extra ventilation in the block side and missing key components.
So a typical good report will be a cascading event with occurrences in R1, less in R2, hopefully only a few in R3, none in R4, and defn none in R5 & R6.
Old 01-27-2024 | 09:18 AM
andy7777's Avatar
andy7777
This is a great report.
There is another version that will show the full diagnostic on the car, whether any system runs a fault. For example, on my Boxster S it showed everything was fine except for a door lock issue.
On the overrevs, you should get the full range from the dealer. I read this to mean there was nothing in ranges 2-6, but I'd get it on paper.
By the way, it's not unusual to get a ghost range 5 or 6 reading that you know is false because it shows a single or two ignitions high up with nothing in ranges under them.
Any buyer would know you drove this like a granny Dave. 🙂
Old 01-27-2024 | 09:42 AM
DaveGee's Avatar
DaveGee
Thanks for all the feedback guys. I get it now. I also have the report below from 2022 which is a more complete picture.
My granny would be proud.😉
DaveGee
Old 01-27-2024 | 09:45 AM
andy7777's Avatar
andy7777
Yup, you hit the redline once, way to go! Now add $5,000 to your criminally underpriced asking price.
DaveGee (01-27-2024)
Old 01-27-2024 | 05:41 PM
fatmike's Avatar
fatmike
498 ignitions above red-line. Range 1, so just above.
Each revolution is 3 ignitions on a flat six engine. So 166 revolutions. We don't know the precise RPMs this happened, but let's assume 7500 to make math easy.
166 revolutions/7500 RPMs = .022 of a minute. .022 of a minute is 1.3 seconds over red-line in the life of the car...
plafondles (01-29-2024)
Old 01-28-2024 | 11:55 AM
Spyder_2011's Avatar
Spyder_2011
Dave I don’t know how you managed to keep off redline with the Spyder, I’ve never driven a car that pulls so hard right up to redline and unless I’m watching the tack its almost inevitable to hit the rev limiter when you’re really getting on it.
Old 01-28-2024 | 11:58 AM
DaveGee's Avatar
DaveGee
I drive with my eyes closed.
DaveGee
Old 01-28-2024 | 12:20 PM
Spyder_2011
DaveGee
Old 01-28-2024 | 11:32 PM
WAILN6's Avatar
WAILN6
There’s another bit beyond what others have already said about ranges. That’s the flash count. Less of an issue I think on this gen, but on 2008 and below you could overwrite the DME. I was on deposit for an orange cayman s sport but it had all 1’s across the rev range and showed multiple flashes. It was a sweet car but I passed not knowing the track history. (Was clearly tracked). So get the full Porsche dealer report and you’ll know.
Old 01-29-2024 | 07:49 PM
Zach L's Avatar
Zach L
If car has 447 hours and the last over-rev occurred at 364 hours, that was about 2.5 years ago or 2,500 miles ago. A buyer should have no concerns resulting from the DME report.
Quick Reply: How to interpret a DME report
