Spec Boxsters For info sharing on this exciting new class
Gas pedal removal courtesy of Van Svenson
Old 04-13-2016 | 01:26 PM
Gary R.'s Avatar
Gary R.
Default Gas pedal removal courtesy of Van Svenson
Was looking for some pictures of what new intrigue I could expect when I remove my gas pedal for modification and came across this post, thanks Van!
https://rennlist.com/forums/996-foru...ml#post4639666
Tried re-posting the whole thing but the pictures didn't come across..
Old 04-13-2016 | 09:46 PM
BostonDMD's Avatar
BostonDMD
Removing your gas pedal is not going to make your car faster.........
Old 04-14-2016 | 12:08 AM
Gary R.'s Avatar
Gary R.
I'm hard wiring it directly into my foot....
Old 04-14-2016 | 11:23 AM
HoBoJoe's Avatar
HoBoJoe
Removing the brake pedal on the other hand...
Old 04-14-2016 | 01:40 PM
gums's Avatar
gums
That's pulling out an old post!
No matter, I still don't know what you guys are talking about.
Never seem to.
Old 04-14-2016 | 01:54 PM
BostonDMD's Avatar
BostonDMD
Never seem to.
Gary is trying to go faster, but he is confused......
instead of removing the brake pedal he is removing the gas pedal......
I don't understand it either......
Old 04-14-2016 | 01:59 PM
gums's Avatar
gums
All I need to do to go faster is to get the car on track.
Seems like I haven't driven in years!
Old 04-14-2016 | 02:50 PM
BostonDMD's Avatar
BostonDMD
Franco ci vediamo a Lime Rock!
Old 04-14-2016 | 03:09 PM
gums's Avatar
gums
Si, al Rocco di Lima!
Old 04-14-2016 | 04:11 PM
Gary R.'s Avatar
Gary R.
Never seem to.
Frank - just ignore Paolo (always a good practice!), it's simple. I do not like the distance between the brake and gas pedal in my Boxster, makes heel-toeing a non-natural motion for me. I am adding an aluminum plate I made to my gas pedal that moves it slightly toward me and adds a tab I can blip easily. To accomplish this I need to remove the pedal itself. While it's out I will clean and lubricate the assembly to assure many years of reliability. That's the whole story!
Old 04-14-2016 | 04:45 PM
BostonDMD's Avatar
BostonDMD
Mamma mia, no more sense of humor in this world!
From now on I'll go hang out with Jacklee........
Old 04-14-2016 | 04:51 PM
Gary R.'s Avatar
Gary R.
Perfect, i'll go to the store and get some cheese to bring to Limerock to go with it...
Old 04-19-2016 | 10:28 AM
ninjabones's Avatar
ninjabones
Gary... do yourself a favor while you have the pedal assembly out o the car; buy the rennline pedal assembly. Trust me! The plastic hinge on the stock pedal is a failure point, especially if you attach a plate for heel-toe'ing. The part fro rennline is pricey, but definitely worth it (and allows for infinite adjustability).
Old 04-19-2016 | 11:29 AM
Gary R.'s Avatar
Gary R.
Originally Posted by ninjabones
Gary... do yourself a favor while you have the pedal assembly out of the car; buy the rennline pedal assembly. Trust me! The plastic hinge on the stock pedal is a failure point, especially if you attach a plate for heel-toe'ing. The part fro rennline is pricey, but definitely worth it (and allows for infinite adjustability).
Thanks Glen, i'll look into the Rennline part. The whole pedal assembly was not bolted down when I went to remove it, bolt just sitting there, pedal box not even secured in its slot properly. Imagine my surprise (or lack of it considering who built this car) when I saw the pedal itself was held in place with two 1" long WOOD SCREWS, just mashing the plastic hooks against the rod that they were supposed to pivot on. I don't even think this is a Boxster gas pedal...
Old 04-19-2016 | 03:02 PM
ninjabones's Avatar
ninjabones
The wood screws through the bottom of the hinge is a common fix for when the pedal pops off. My bet is that this same issue affected the prior owner. Trust me.. been there, done that. Lasts about 1 race before it pops off again. The whole assembly is a plastic piece of crap. Now that you've done the hard part (i.e. removed the pedal), it's a quick job to modify the stock base to accept the rennline bit.
Quick Reply: Gas pedal removal courtesy of Van Svenson
