Spec Boxsters For info sharing on this exciting new class
Third Radiator Necessary?
Old Jul 14, 2015 | 05:23 PM
nolocontendere's Avatar
nolocontendere
Default Third Radiator Necessary?
Is a third radiator really necessary for a spec boxster that has all the other bells and whistles? Car will run in texas summer heat
Old Jul 14, 2015 | 07:25 PM
Bill Lehman's Avatar
Bill Lehman
I don't run a Spec Boxster but run a Cayman S and have about 100 track days. The 3rd radiator is a cheap drop in part. It definitely reduces water and oil temperature. If I lived in Texas I would consider it mandatory.
Old Jul 14, 2015 | 10:54 PM
jdistefa's Avatar
jdistefa
Number 2 rod bearing. Yes.
Old Jul 14, 2015 | 11:14 PM
JML47's Avatar
JML47
I do without, and haven't had any trouble running at VIR with ambient air temp in the 90s.
Old Jul 15, 2015 | 07:27 AM
J richard's Avatar
J richard
I run in AZ it is absolutetly req in the hot afternoons. Disclaimer that I run sans fans, idling on grid too long will raise temps, but I'm surprised by how well it works. A cup with essentially the same setup overheats in short order on grid.
Old Jul 15, 2015 | 03:13 PM
mmuller's Avatar
mmuller
Yon don't have a third Rad do you?
Old Jul 21, 2015 | 06:38 PM
jdistefa's Avatar
jdistefa
^ Matt - nope.
Ran two rads (cleaned diligently every season), one fan removed for better flow, one left in for idle... and a Setrab external oil cooler with fanpack.
After VIR I'm going to add a 3rd radiator. Best guess re. accumulated experience is that the 3rd rad will drop water temps 5-10 degrees. Every bit helps.
Old Jul 22, 2015 | 01:10 AM
mooty's Avatar
mooty
GT3 player par excellence
i run no fan.
you should do 3rd radiator. #2 bearing as stated and also it's cheap so there is NO reason not to have it.
you should also consider trans/diff cooler. the 4 cars i know that do not have diff cooler each needed 2 trans per season.
Old Jul 22, 2015 | 03:55 PM
Andrew D.'s Avatar
Andrew D.
I run a 3rd rad and no fans. It works well in California heat.
