Spec Boxsters For info sharing on this exciting new class
Tranny Cooler
Old Feb 22, 2015 | 06:49 PM
gums's Avatar
gums
Default Tranny Cooler
So where is the tranny cooler on these things?
I can't tell if I have one.
Old Feb 22, 2015 | 06:59 PM
sbelles's Avatar
sbelles
I'm in....
If you can't tell then you don't have one. The plumbing is pretty obvious.
Old Feb 22, 2015 | 07:08 PM
gums's Avatar
gums
yeah, I was afraid of that.
Is it a necessity?
Hate to blow the trans.
Old Feb 22, 2015 | 07:13 PM
sbelles's Avatar
sbelles
I'm in....
I use mine but the cooler is in the truck so I'm not sure how much good it does. I think changing the oil frequently is the most important thing. Smells pretty bad after a while.
Old Feb 22, 2015 | 07:31 PM
Paseb's Avatar
Paseb
what's the best trans cooler?
one mounted in the center bumper or one with a fan pack next to the engine?
Old Feb 22, 2015 | 07:51 PM
gums's Avatar
gums
You mean trunk, not truck, Scott?
Is that one of the switches on your dash that we turn on?
It has a fan?
Old Feb 22, 2015 | 08:44 PM
Streak's Avatar
Streak
Perfect Angel
When my tranny gets too hot I tell him/her to get out of the sun
Old Feb 22, 2015 | 11:11 PM
sbelles's Avatar
sbelles
I'm in....
It has a fan?
Yes, it's in the trunk and the switch is on the shift riser. No fan, just a pump. The truck has one too but that's different.
and I wouldn't touch Streak's tranny with a 10' torque wrench.
Old Feb 22, 2015 | 11:14 PM
gums's Avatar
gums
Ok, so who sells what I need?
Old Feb 23, 2015 | 12:31 AM
Dave DE's Avatar
Dave DE
Here's one source: http://shop.tunersmotorsports.com/?p...oil-cooler-kit
Old Feb 23, 2015 | 01:39 PM
jdistefa's Avatar
jdistefa
Now I remember who had blown a tranny. Ugh.
Old Feb 23, 2015 | 03:03 PM
gums's Avatar
gums
Let's be very clear here:
I do not want to blow my tranny.
I do not want to blow my engine.
I will be out of business.
Along those lines, what about these deep sump kits? Worth it?
Old Feb 24, 2015 | 07:52 AM
Deadeye's Avatar
Deadeye
I'm currently working with a raditor fabricator on a protoype cooler that will replace the ac condenser with the same mounting lugs for a simple install. This will require longer lines, but much better cool air flow. My plan is to put one on the other side for engine oil cooling.
Old Feb 24, 2015 | 02:22 PM
sbelles's Avatar
sbelles
I'm in....
If it doesn't have one, an x51 oil pan with baffles is a good idea.
Old Feb 24, 2015 | 07:12 PM
Greg Holmberg's Avatar
Greg Holmberg
Default LN Engineering oil pan
Anyone tried this one? Any good?
Bilt Racing 2QT Deep Sump Oil Pan Kit inc. Pickup-Tube Extension, Windage Tray & X51 Baffle
