Spec Boxsters For info sharing on this exciting new class
Water pump suggestions.
Old Jul 28, 2022 | 02:00 AM
maekwl's Avatar
maekwl
Default Water pump suggestions.
I want to replace the water pump in my 986. Besides having a plastic impeller is there anything else a water pump should have?
Should I be looking for oe/oem or should I get it from Porsche ?
any recommendations if not Porsche ?
Thanks for the help
Old Jul 28, 2022 | 08:59 AM
Nickshu's Avatar
Nickshu
Nothing special here. Porsche or OEM equivalent (Pierberg I think?). Avoid the metal impeller ones, Porsche used plastic b/c if the bearing fails then it won't eat into the aluminum block. Get a new gasket, they are crush gaskets so can't be re-used. The pumps I have bought always come w/ one, but make sure. You have to cut the gasket b/c it's shared w/ one of the oil galleries, Pelican how-to guide shows where to cut it. I usually get new bolts too b/c they are cheap, not included w/ pumps. Torque is 11 ft lbs like most things on the block.
Old Jul 28, 2022 | 03:05 PM
maekwl's Avatar
maekwl
Thank you! I saw about cutting the gasket but didn’t know why.
I don’t know much about cars I’m trying to learn that via converting my 968 into a SPB.
Why not replace what ever shares that gasket ?
Old Jul 30, 2022 | 04:43 PM
Quadcammer's Avatar
Quadcammer
Its part of the oil pump console and there is no reason to replace it
Old Aug 2, 2022 | 08:58 AM
RennPart's Avatar
RennPart
Basic Sponsor
I use and sell the Pierburgs.
Make sure you take note of the length of the bolts as you take them out and mark their location. They are not all the same length. Also be careful not to cross-thread the one bolt that is tougher to get to.
https://www.youtube.com/watch?v=1FsXzVkv6fU
https://rennpart.com/product/water-pump-and-gasket/
rennpart.com | Phone: 336-793-2134 |Email: ace@rennpart.com | totalbrakes.com
FSI - LN Engineering Certified IMS Solution Installer
Instagram | Facebook
Old Aug 2, 2022 | 09:20 AM
maekwl's Avatar
maekwl
Thank you for the tips and the link. I would be the person to cross thread. I’ll shop you for my next parts purchase. I was at the dealer for a classics reveal and just bought it there.
putting the bolts into cardboard in the order & rough location they were taken out has saved my butt in many situations.
Old Aug 2, 2022 | 01:48 PM
steved0x's Avatar
steved0x
The cardboard is what I did, that is a great idea. There are two that are different and I think they might correspond to the two holes that have a little bump out to help line up the water pump.
