Rear Adjustable LCAs - Advice needed
Hello SPB Brothers,
I'm in the process of adding the GT3 rear lower control arms and need some advice:
- Should I use the center hole or the offset hole for the diagonal arm? I used the offset hole in front, but choice of holes for rear seems less obvious.
- Is there any good way to lock the inner mount or should I just keep the eccentric adjuster?
- What's the right amount of shims? I put in 13mm per side and kept the eccentric adjuster for now.
Thanks for any tips you can offer.
Use the center hole for the rears. Tarett sells a locking piece. If you keep the eccentric, mark it with paint or sharpie so you can see if/when it gets knocked out. The number of shims depends on desired camber and ride height. Lower height or more shims create more camber (and change the toe).
