Camshaft position sensor location
Help, we can't find the camshaft position sensor for bank 1. 2001 Porsche 996 3.4l. Please help . We just found about that the engine code is for a 99 3.4l. So I'm guessing it's had a engine swapped, but please help with the location of the camshaft sensor bank 1
Pelican have a diy on this subject also , Search works well!
https://rennlist.com/forums/997-turb...-location.html
There's one on the drivers side of the motor (bank 1) near the flywheel where the motor mounts to the transmission. I thought this is the crankshaft position sensor though??? Obviously the crankshaft and the camshafts are all connected/timed to each other via chains so perhaps the names is not all important...
On a 2001 engine like this it is the near side black connector on top of the head:
That's A good picture, but we still can't put our hands on it, I'm not sure if we're in some type of twilight Zone, or in some kind of fifteen dimension . But can some please tell me how to change this, what's the proper steps, I just don't know what's up
I'm feeling and seeing a lot of wires in that location, I'm feeling some type of tube going into the engine, I'm feeling something with clips like a fuel injection piece, I see the green plug on my engine, then when I reach for that sensor, all there is , is a tube with rubber going into engine, I see some fuel injection stuff, I feel wires, I do not feel anything close to what that part looks like, I've even had help, with no luck, we have a 4wd car here, same as mine, we can see that sensor, in plane view and can touch it on the Carrera 4 but my c2 , no way no how, someone lend us a hand here please, what's the procedure to changing this cam shaft position sensor on a 3.4 C2 996 3.4. With a 1999 reman Porsche engine it seems? HELP
911user (07-28-2021)
AHS it is a bear, I see it tucked away , I feel it I'm sure, I think. I just took pictures of engine, can anyone confirm what year engine this is, my car is 01 996
Engine numbers, Sorry about the mess, Once I get this car running properly, I'll get it spotless!!
I've been "in there" recently and have the healing scars to prove it. Suggest you combine this with an AOS job. It is so tight in there ,that was the only way I could see to do it.If it makes you feel better about all the work add a camshaft timing check(greenplugs) to the to-do list.
Others may have smarter suggestions.
You might give some details of why you think it needs changing.They are not usually troublesome compared to some other sensors.I would hate to read that you did all this work and it was not effective. If you are getting a cam timing code, post it and we'll help you
Good luck
Good luck
My car has a blinking cel light, right from start up, it has no power , feels like it's running on just a few pistons. It bogs, upon full throttle it's just limping and surging around. It will not pull at all, I rode in a healthy 996 and it's night and day different between the two identical cars
