996 Turbo Forum 1999-2005
change of tune causing HP loss?
Old May 29, 2026 | 12:15 AM
joseph mitro's Avatar
joseph mitro
Default change of tune causing HP loss?
Long story short - my 996TT was purchased as a MAFLESS setup with an unknown tune and 1000cc Cobb injectors. I repeatedly got CEL with codes 1145 and 1155 for O2 sensors.
My local independent Porsche mechanic (who I've used for 20 years) recommended I reinstall a MAF, reinstall stock injectors and stock FPR, and place a GIAC tune to eliminate several possible reasons for the CEL codes.
Supposedly the GIAC tune was to give me 100hp over stock. After receiving the car back, I took it for multiple full throttle pulls in 1,2,3 gears. I saw only 0.6-0.7bar boost on the stock gauge rather than the 1.1-1.2 I previously saw. The car also feels noticeably slower - no longer a big rush after 3000rpm. So I'm wondering if my car is simply back to stock performance. At least no CELs appeared.
my question is - wouldn't I be getting 1.0-1.1 bar of boost if i truly had a tune giving me 100 more HP than stock? what factors would influence the perceived drop in performance?
Old May 29, 2026 | 12:58 AM
yvvvz's Avatar
yvvvz
.6 to .7 is less than stock boost. Could be happening for many reasons. I would look for a boost leak first. Check for obvious places first like the big boost tube connections at the intercoolers, the Y pipe, etc.
Old May 29, 2026 | 09:46 AM
vtec_'s Avatar
vtec_
not sure what the GIAC tune targets...regardless it would need to be scaled for thosee injectors
Old May 29, 2026 | 03:02 PM
docwyte's Avatar
docwyte
I'd imagine the GIAC tune is a 1 bar tune. However, their tunes are meant for stock injectors, were those reinstalled?
Old May 29, 2026 | 04:44 PM
vtec_'s Avatar
vtec_
If this was my car I would return it to stock and make sure it is running right before going with bigger injectors, tunes, etc but I get that not everyone can work on their own cars or have time constraints (the injectors aren't exactly easy to change like in some other cars)..so..he could return the rest of the car to stock and reach out to a tuner who can comptently scale the stock map with the new injectors to make sure everything is running right..then go from there.
Old May 29, 2026 | 05:57 PM
joseph mitro
@docwyte yes the stock injectors were installed to replace the cobb units
@vtec_ yes thats exactly the train of thought. I did a lot of work to pin the coolant lines but when it comes to diagnosis i leave that to the professionals. I don’t know much about tuning.
I dont see anything that would suggest a boost leak; I just need to talk to my mechanic when he’s available to try and sort it out.
thanks for the input
Old May 29, 2026 | 05:59 PM
joseph mitro
@vtec_ what is involved with getting a custom tune as opposed to off the shelf tune?
Old May 29, 2026 | 08:09 PM
vtec_'s Avatar
vtec_
reaching out to a porsche tuner like @Kevin and they will send you a base map file, you do the logging and send it to them and they send you an updated file based on the results
kevins (umw tuning) datalogger and the cobb accessport are the only tuning solutions that i know of that provide the ability to log knock sums by cylinder
there are a handful of cobb certified tuners that deal with porsches
Old May 29, 2026 | 10:10 PM
993GT's Avatar
993GT
leak test your diverter valves
Old May 29, 2026 | 11:57 PM
JBear's Avatar
JBear
I'm lost, did you recenly buy this car? Do you have a complete list of modifications? Are you sure the turbo's are stock? Very unusual to install fuel injectors with that type of flow on a stock car, either the stock turbo's were bolted back on before the sale or they are upgraded in some way, hybrids or other.
Not sure I would have swapped the injectors before knowing more.
Old May 30, 2026 | 09:00 AM
joseph mitro
Ive had the car 4 years. It came with absolutely no records. It ran like a raped ape until now, but with the CEL always on. It was mafless and had straight pipe exhaust (loud) and k&n air filter on the turbos. The turbos and wastegates appear stock. I discovered the cobb injectors when i dropped the engine to pin coolant lines.
my mechanic’s rationale to make the CEL go away was to put it back to “stock” configuration and then use a GIAC tune that would only work with stock injectors and MAF.
Old May 30, 2026 | 10:46 AM
docwyte's Avatar
docwyte
I'm not a huge fan of the GIAC tune, but it should still be making 1 bar of boost, so you definitely need to leak test the car. The "Big 3" for tuners for these cars are Kevin@Ultimate Motorwerks, Markski and Sam@By Design. Do you still have the original tune? If you put that back in and immediately boost goes back up, then it's the GIAC tune and nothing else.
What was the CEL on for?
Old May 30, 2026 | 02:52 PM
joseph mitro
oxygen sensors.
i do not have the original tune.
i appreciate all the input
Old May 30, 2026 | 05:45 PM
vtec_'s Avatar
vtec_
do you have the original exhaust?
Old May 30, 2026 | 06:47 PM
SSDVC's Avatar
SSDVC
Veteran: Navy
Why didn't you just try and replace the O2 sensors first ? Seems like a lot of money dropped for nothing.
