996 Forum 1999-2005
Oil question, sorry in advance, Im confused, DT40 or DI40??
Old Apr 22, 2026 | 10:10 AM
studawg's Avatar
studawg
Default Oil question, sorry in advance, Im confused, DT40 or DI40??
So Ive read that the DT40 was developed specifically for the M96, but also read that DI40 is better, from seemingly knowledgeable people on the subject! So which is it?!?!
My vehicle is a 2000 911 C4 manual with 163k miles. Engine rebuilt at 137k. I live in SC, I drive it hard, daily driver, but I dont track it.
Old Apr 22, 2026 | 10:19 AM
GC996's Avatar
GC996
Here you go.
Driven DI40 / DT40 & pca Video - Rennlist - Porsche Discussion Forums https://share.google/987yaol0BuXRYr6Wh
Old Apr 22, 2026 | 10:25 AM
Charles Navarro's Avatar
Charles Navarro
Platinum Sponsor
If you street drive the car, DT40 is great. If you have mixed use including track use, DI40 (or DI50 if your oil temps are sustained above 225F or peak 240F) is what you should run.
https://lnengineering.com/products/driven-racing-oils/
Old Apr 22, 2026 | 11:38 AM
studawg's Avatar
studawg
Ok Im going with DT40, thank you!!!!!!
Old Apr 22, 2026 | 12:48 PM
allcool's Avatar
allcool
Might help to see what Porsche's recommendation on oil viscosity currently is for our 996.1 & 996.2. The "50" is the important thing to note, regardless of brand type, especially in a southern climate going into summer, driving it hard.
Old Apr 22, 2026 | 05:45 PM
studawg's Avatar
studawg
I know, and Ive seen that. The fact that Porsche recommends a 50 weight and an oil that was designed for the M96 is a 40 weight is hard to square. I guess Im back to square one. I dont know what to run.
Old Apr 23, 2026 | 01:13 PM
bones519's Avatar
bones519
Newer to 996 ownership so I’m sure I’m missing something obvious, but just curious where you heard that the Driven 40 weight oils were designed for the M96? Going on the Driven website, I didn’t see any specific mention of Porsche other than “DI40 has an active following in the Porsche community”. DT40 page just says its used for German, Italian, British sports cars and Chrysler 6.4L hemis, as well as for European turbocharged engines. I have definitely heard about the many positive benefits of the oil in our engines, but was just curious about the “designed for” comment as would think it would be specifically called out on the website. Thanks!
Old Apr 23, 2026 | 01:27 PM
GC996's Avatar
GC996
Lake Speed who was the tribologist at Driven worked with Charles Navarro and Jake Raby to develop DT oil for the M96. Later the DI oil was developed which many of us prefer. Both are excellent high moly, high viscosity oils. DI can be run on both the street amd track, whereas DT is for the street.
Watch the video I attached early on in the thread. It will fill you in.
Old Apr 23, 2026 | 01:31 PM
AeroF16's Avatar
AeroF16
Thanks for that. Is there any reason not to run DI on a street use car? Is it overkill and extra $$$?
I don’t usually drive my car that hard but once in a while it gets the old Italian tune up.
Old Apr 23, 2026 | 01:37 PM
GC996's Avatar
GC996
DI is more expensive would be the only downside. I run DI50 on both street and track. If I didnt track my car I would still run DI. FwIW, if you live in a cold weather town amd want to drive your car during the winter, you may want to consider running DI40 in the cold weather months and then switch to DI50 in the warm weather months. DI50 is higher viscosity than DI40 and will improve the oil pressure.
Old Apr 23, 2026 | 02:12 PM
Charles Navarro
Platinum Sponsor
The Driven website leaves much to be desired. I have brought this up to them on several occasions.
However, if you do contact Driven regarding Porsche applications, they just forward those inquires to us as they don't have any European specialists on their support staff. I myself deal directly with the person in charge of formulations.
Jake and I did the testing for Driven in Porsche engines way back in the day. In subsequent years, Driven purchased a Boxster and did extensive OTR testing on that platform to back up our results.
Although Lake may not be at Driven any longer, he still drives a Boxster. LN's in fact, with a 3.8 with plasma sprayed bores that has been on the road since 2019.
All this aside, just look at the used oil analysis results shared by other forum members with their use of DT40. There really isn't any other reason to use any other oil in your street driven Boxster, Cayman, or 911.
Old Apr 23, 2026 | 03:44 PM
bones519's Avatar
bones519
https://youtu.be/Ca2UbzBzBNw
Got it, thank you for this. Guess I have more to catch up on!
Old Apr 23, 2026 | 03:58 PM
bones519's Avatar
bones519
Thanks, remember watching that a while ago but will rewatch - must have missed some of it.
Old Apr 24, 2026 | 09:58 AM
studawg's Avatar
studawg
Thank you so much for the input. One more question, just to confirm, and I promise Ill drop it LOL. Considering 1) I live in South Carolina (its hot), my car has 163k miles, 2) it was rebuilt 25k miles ago which included honing and ridge-reaning the cylinders (which I assume might increase internal tolerances a little bit?) and 3) I tend to try to drive hard on the street (but not track), do you think it would make sense for me to run a 50 weight oil?
Old Apr 24, 2026 | 11:25 AM
allcool's Avatar
allcool
Was this 'rebuild' on oem @163k miles Porsche lokasil cylinders, or on previously built sleeved niksil or steel cylinders...?
