Fuse Plan for 997.1?
Apologies if this has been asked before, but I did an advanced search of this forum section and nothing came up with it.
My new-to-me 2006 997.1 doesn't have the Fuse Plan on the back of the fuse box door. I have no idea what any of the fuses go to. I'm having an issue with the windshield washer pump and I don't want to just start pulling fuses out one by one to see if they're blown or not. Is there another source for the info or can anyone tell me which fuse is for the washer pump? Better yet, a picture or pdf of the fuse layout would be great.
Thanks.
Thanks.
Yorik (09-23-2024)
Graufuchs (09-23-2024)
There doesn't seem to be a fuse for the windshield washer fluid pump listed. Only the headlight washer system and that fuse is good. Still not getting washer fluid.
Does the pump have a relay?
Put your meter in continuity check mode (beeps when the leads are touched together) and insert the pins into the back of each fuse. You can check the fuse continuity this way without removing them. Can check all of them in about 2 minutes going from one to the next.
Yorik (09-24-2024)
