Bore scoring found - now what?
Old Yesterday, 05:00 AM
azmousss
azmousss's Avatar
Default Bore scoring found - now what?
Hi All,
130K Miles
2005 997.1 manual/stick shift carrera
Thanks to this forum I began learning about the biggest risk to these cars is bore scoring. i still don't quite understand the history and why is it only these cars in the world have it. but i'm grateful because i asked my mechanic to do the check with the camera and below are the results. And i learn about that check/control on this very forum.
the mechanics conclusion was : yes there is bore scoring. it isnt a surprise. it isnt "bad" . i can continue driving the car and oil change to be done every 10K KM and check with the camera at each of these intervals.
Please do you have any advice/input/guidance?
Thank you as always
Old Yesterday, 07:27 AM
EVOMMM
EVOMMM's Avatar
Received 1,664 Likes on 972 Posts
Look drive it till it pops
in the mean time use a good oil like driven DI40 and make sure your injectors/plugs are new
drive it hard at temperature regularly
enjoy the blasts
look for a reputable builder or replacement engine
The following 4 users liked this post by EVOMMM:
alaris (Yesterday), azmousss (Yesterday), Bwoy1981 (Yesterday), myltz400 (Yesterday)
Old Yesterday, 07:30 AM
rtl5009
rtl5009's Avatar
Unless oil consumption is crazy drive that sucker.
The following 2 users liked this post by rtl5009:
Old Yesterday, 07:57 AM
alaris
alaris's Avatar
Switch to Driven oil
Install a low temp thermostat
Install a magnetic drain plug and oil filter attachment
Increase frequency of oil changes to 7000-8000 km
Drive and enjoy. You’ve got a lot of life left in the engine.
The following 2 users liked this post by alaris:
azmousss (Yesterday), da Vinci Dan (Yesterday)
Old Yesterday, 09:18 AM
da Vinci Dan
da Vinci Dan's Avatar
Your mechanic knows what he is talking about. It doesn't look bad. If you never heard of there being an issue and did not investigate, would you have ever discovered this? My guess is no. Just drive it, add oil if needed. If oil consumption gets out of control (too much smoke for you, too much consumption for you), then send this post to the top again. My guess is that you could drive your car for 10's of thousands of miles like it is.
Drive it and enjoy! I'll look for your post in 10 years.
Edit: Listen to alaris above
The following 2 users liked this post by da Vinci Dan:
Old Yesterday, 09:19 AM
rsinghal3
rsinghal3's Avatar
not sure if its just me but that looks to be close to no bore scoring/very normal amounts for a healthy engine. plenty of life left as others have mentioned I wouldnt even think about it
The following 4 users liked this post by rsinghal3:
alaris (Yesterday), azmousss (Yesterday), golftime (Yesterday), TRINITONY (Yesterday)
Old Yesterday, 10:35 AM
yelcab
yelcab's Avatar
Really? What borescoring?
Want to see borescoring? This is it.
alaris (Yesterday)
Old Yesterday, 10:41 AM
Sylverlee
Sylverlee's Avatar
For 130k miles I’m pretty sure that is good
Old Yesterday, 10:51 AM
azmousss
azmousss's Avatar
i only knew about what to check via this forum and how to check it. thank you as this is what i plan to do. this is my daily driver. and its such a pleasure to drive.
Old Yesterday, 10:52 AM
azmousss
azmousss's Avatar
forgive my stupidity so truly bore scoring is the "excess" of lines ?
Old Yesterday, 12:41 PM
MrMoose
MrMoose's Avatar
Yeah, I don't think you can tell anything from those pics. Even a healthy engine will have some burnishing of the cylinder walls. In the absence of any issues like smoking or burning significant oil I'd just drive it.
The "scope it every 10k km" thing from your mechanic makes no sense. What exactly is that supposed to do for you? If it gets worse you'll know from other symptoms, and it's not like you can do anything if it's scored (besides wait until it's bad enough to need a rebuild).
This site'll make you paranoid about bore scoring. Just drive the car, change the oil regularly, and use a bottle of injector cleaner say once a year.
K996 (Yesterday)
Old Yesterday, 12:52 PM
punchdrunked
punchdrunked's Avatar
Why o why do folk ask their mechanic to peer into the bores of these cars when there’s no need to? Do you want to be kept awake at night until you’ve dropped 5 figures into the car to stand still, more if you want more powarrr. Sadly you’ve gone there - regardless of what folk say, you’ll worry about this now. Sorry.
I’ve got a 3.6 with 136k miles. No oil usage, no smoke on start up, no ticking, no soot - I just drive it. I’ve also got a 3.8 with Borescore, tippy tappy piston slap, soot, the works, but I drive it hard. When it breaks I’ll fix it.
Enjoy
alaris (Yesterday)
Old Yesterday, 01:39 PM
groovzilla
groovzilla's Avatar
Received 4,917 Likes on 2,905 Posts
Those are terrible out of focus photos and they should re-do inspection photos for you
The scoring probably isn't bad at all.
idylldon (Yesterday)
Old Yesterday, 01:49 PM
B453D
B453D's Avatar
If you don't already do so, get used oil analysis from SPEEDiagnostix at every oil change so that you have data and can indentify trends (I would change the engine oil every 3K).
alaris (Yesterday)
Old Yesterday, 02:17 PM
Tom R.
Tom R.'s Avatar
LS Swap or Honda swap!!!
Quick Reply: Bore scoring found - now what?
